LemonConnoisseur
On a high from the success so far, as the intake was off and a usually difficult to access torx bolt was now basked in glorious light and ease of removal, I decided that it would be a smart idea to change the oil filter housing and oil cooler gaskets as I had meant to do them before but couldn't due to tool limitations. This is where everything started to go wrong.
I'd read a couple of guides/watched a couple of YouTube videos beforehand to get an idea of what is involved. In videos, as is always the case, it doesn't look too difficult and everything comes off with ease! In reality, that really is not the case.
With the oil filter removed, it was time to begin.
After removing one of the, usually, difficult to access bolts, I was feeling smug. Very smug. "Phwoar, with the intake off, this is gonna be a piece of piss!"
How foolish of me.
I could remove both of the upper torx bolts on the filter housing with no problem, placed them to one side. Tried to tug it, it moved a bit but felt as though it was stuck. It was only then that I remembered the infamous third bolt, that sits right next to a coolant flange. Bollocks.
I tried to get a spanner on it, no luck. Then tried a socket, no luck. Ok, so that coolant flange is going to have to come out. No issue, two 10mm bolts, a slight pull, and...
For f**k sake.
Now, after doing some research in hindsight, I realise that these are a brittle piece of plastic that are known to fail. Lovely!
I was pretty deflated when this happened, but at least with it out I could now access the last bolt keeping the filter housing in place.
This proved to be a right little bastard to remove. I've never tried to remove a bolt with worse space than this, not a pleasant experience in the slightest!
But, with that removed, it was free! Sort of.
My new E-spanners, although the correct size for the stupid bobble bolts, couldn't get any purchase on the one situated underneath the oil cooler. The 2 coolant pipes that connect to both the cooler and filter housing needed to be removed, which caused coolant to go absolutely everywhere - great. I then lifted the filter housing out, and as I should have anticipated, oil then went everywhere to join the coolant in the undertray/all over the driveway. Much blue roll required to try and catch any last drops that hadn't evacuated from the system, it was not very successful.
With the filter housing and cooler now out, slight joy returned as I could now get to the last bolt! Also, judging by the state of both components, I'd say this has been leaking for a while.
Gaskets have seen better days, too!
New gaskets, Elring items. They came with the car which was handy.
Attempted to give both parts a clean with Aldi's finest kitchen cleaner 8)
Better than it was before anyway. Also cleaned up the mating surfaces and fitted the cooler back onto the housing with some new bolts I got from BMW.
How foolish of me.
For f**k sake.
