exdos said:Vanne, That's very serious wear. I'm wondering if this might have something to do with your permanently hot climate in Dubai affecting a high-performance engine often driven at/near its limits?
That may very well be a factor....
ga41 said:exdos said:Vanne, That's very serious wear. I'm wondering if this might have something to do with your permanently hot climate in Dubai affecting a high-performance engine often driven at/near its limits?
It could be the oil and in view of my observations of wear being similar on all 6 cylinders, it could indicate that the hot climate is affecting the tolerances between the bearing shells and the crankshaft?CornishRob said:Is this the hot weather effecting the oil or something else?
Your guess is as good as minemmm-five said:Are they dealer prices (i.e. 7-10 hours @ £150/hour), or is it really a 20-30 hour job at an indy (£50/hour)?GuidoK said:Labour maybe 1000-1500?
£120-£180 an hour, depending on location.GuidoK said:Are dealerrates in the uk £150/hour?!?
... That's insanemmm-five said:£120-£180 an hour, depending on location.GuidoK said:Are dealerrates in the uk £150/hour?!?
exdos said:It could be the oil and in view of my observations of wear being similar on all 6 cylinders, it could indicate that the hot climate is affecting the tolerances between the bearing shells and the crankshaft?CornishRob said:Is this the hot weather effecting the oil or something else?
srhutch said:Can't see that one myself. The engine temperatures will far exceed any environmental temperatures once fully up to temp.
exdos said:srhutch said:Can't see that one myself. The engine temperatures will far exceed any environmental temperatures once fully up to temp.
I agree with that. I'm just thinking that the tolerances for cold starting in sub-zero temperatures yet getting up to full operating temperature, might be different for cold starting in a hot climate which might have an effect, because the operating temperature range would be different?
tomscott said:But Ms are bulletproof… :?
Been saying this for a long time they are wearable items this does look an extreme case probably the worst I've seen. Get it done between 80-100k £1k for parts and labour is more like the figure, £2k sounds a lot.
While your there tho get the engine mounts and bolts done too, probs £13-1500
You've said what I was trying to say, but you've phrased it better.CornishRob said:Could it be that as the engine will be warmer when not being used, the tolerances will be slightly tighter, so if most damage is done from a cold start, as its just that little bit tighter, they could be getting worn before the oil could get warmed up and do its thing.
exdos said:You've said what I was trying to say, but you've phrased it better.CornishRob said:Could it be that as the engine will be warmer when not being used, the tolerances will be slightly tighter, so if most damage is done from a cold start, as its just that little bit tighter, they could be getting worn before the oil could get warmed up and do its thing.![]()
