Rpi scoop and afe intake..
Stuart Truman said:
Possibly the most technical :hijacked: ever... :D
Too bloody right, here's me;
"Oh I wonder what is going on in this popular thread....*click*.... WHHHAAAAAAAARRRTTT???????????" :dizzy:
aerobod said:
No, there is no difference in the calculations, or the values. The value you have calculated for your car, the value I am quoting is BMW's stock value. There is only one formula, but different units can be used.
Your calculations are based on your observations, as opposed to BMW's quoted values. It has been known for cars to be stronger than the quoted values by a fair margin, but there are a few things to consider when extrapolating values from indirect observations to a derived value:
1. Value for losses - 15% is a reasonable guess for most rear wheel drive vehicles, but this can easily be from 10% to 20% and will vary under different conditions for the same vehicle based on a large number of parameters:
- Tyre choice - µ (friction coefficient) can vary between 0.8 and 1.2 with rolling resistance variations (with a slight speed dependency) from 0.008 to 0.02, depending on tyre compound, temperature, pressure, etc.
- Driveline losses - very dependent on oil, temperature, selected gear (especially between direct drive gears with a 1.00 ratio and any other gear), condition of components (especially differential).
- Road surface texture - affects µ and therefore rolling resistance.
2. Drag variations - the drag coefficient of a given car can vary a lot from the nominal manufacturer's value. Configuration changes such as different wheels, wider tyres (affects the projected cross section), different mirrors, variation in panel gaps,ride height, can easily alter the drag by 10%. At Vmax, a +/-10% drag variation will cause power estimates to vary by +33%/-27%.
3. Environmental variations - easier to estimate, as air density and temperature are fairly well understood in how they affect power output and drag values, but humidity is a bit more of a wild card with both positive and negative affects on given engines. Heat soak of the driveline components can also modify the power to the wheels, as demonstrated by the change seen in repeated dyno runs or hard track day usage.
i'm sure I could think of a lot more variables, but the point is that using a Dash Dyno or a stationary dyno both have pros and cons. I believe that in any case they are useful for comparison of change, as long as the variables mentioned above are kept consistent from test to test. The problem is that neither are very good at giving absolute power outputs, due to the use of "correction factors" that may be arbitrarily assigned. The only really accurate way of measuring engine power is to remove it from the vehicle and run it in an environmentally controlled test cell, together with an accurate air flow that represents both the speed and flow characteristics of the front of the car into the air intake.
With the Dash Dyno, I would push the manufacturer to provide the equations and all input parameters they use, to evaluate their assumptions and limitations. Without that info, basic equations and time-to-distance measurements to compare changes should be at least as accurate, if the test is done in the same gear over the same rev range.
Thanks for your input. :thumbsup:
I appreciate the points that you've made. I've always made it clear that I make no claim to the absolute accuracy of dyno results produced by the DashDyno, because, as you say the only way to get such accurate figures is to remove the engine from the car. Then again, I wouldn't be measuring in "real-world" driving conditions in that scenario. As far as I'm concerned, there is no other way that I would be able to test and monitor changes in my experimentation with air-intake and exhaust mods without the use of a DashDyno or other similar datalogger connected to the car's ECU via the OBD II socket. Sometimes a tape measure is adequate, whilst other times a micrometer is required, and I think for my purpose, the DashDyno is a good enough tool for the job. It's certainly a better tool than mine, or anyone else's, butt dyno. :wink:
Yes, isn't it amazing! A technical thread on performance on a popular car forum. :rofl: :driving:
Can you just datalog time, distance and RPM with the DashDyno and output that as raw data? That would be useful to apply different equations and scenarios to, together with the environmental conditions and tyre size and model at the time of test.
Does it give the capability to input tyre parameters such as variation in rolling radius with acceleration g-force (leading to squat), tyre type and tread depth? This parameter can actually change the effective gearing quite a bit, compared with just inputting the tyre size. Even a worn (but legal) tyre can be 2% different in rolling radius than a new one, in the case of the Z4M leading to a 7bhp over estimate of the engine power.
It would be great if you could provide some comparative raw data, it would be interesting to see how some of the basic modelling I've done on the Z4M in the past would compare with the DashDyno modelling.
Keep up the good work!
With the DashDyno you can run it in "datalogger mode" or "dyno mode", where in datalogger mode you record any of the PIDs that the ECU will yield as raw data, or in dyno mode, you need to use a vehicle profile for dyno runs or acceleration timings.. I'll have a look for you tomorrow if it's possible to produce the specific data you suggest.
With regard to the PIDs that can be recorded: different vehicles will yield a different selection, and the Z4MC yields lots more than my Z3MC does. The Z4MC actually yields Air/Fuel ratios, which I've found useful. With regard to tyre diameter: I do account for tyre wear in my vehicle specific profiles to keep the data as accurate as possible. There's no facility for recording g-force.
Until this thread, I've never previously used BMEP as a measure of changes in engine performance because it uses the derived figure of torque from the dyno facility. Instead, I've used Volumetric Efficiency which I compute from the raw data using the PIDs of Engine RPM, Intake Air Temperature (IAT) and airflow through the MAF. I've made a template in Excel, which will compute a "rolling VE" which can be plotted on a graph against the other PIDs on a timeline. I've found this to be an invaluable help in understanding how the air-intake actually works and how modding the intake and exhaust affects the VE.
If you send a PM with your email, I'll send you a sample of raw data for you to look at and play with. likewise, I'd be very interested to learn what you've been doing. :thumbsup:
Aerobod, thanks for your PM, I've sent you some data for you to play with. Enjoy! 8)
I know that many people are sceptical of the improvements that can be achieved with a ram air-intake (and I'm not referring to a metal pipe with a cone filter stuck on the end, but that's probably what most others are thinking of????), but when I've done the calculations, as shown in this thread, it's clear that all my figures tie up with each other. I've already shown the BMEP figures for a turbo-charged BMW engine, so I thought I'd find some information for a supercharger for the S54 engine.
Here's a link to the Active Autowerke Supercharger kit : http://store.activeautowerke.com/ac...eneration-7-supercharger-kit-level-2-p44.aspx This produces a Maximum Torque of 395 ft/lbs @ 5400rpm. Using the agreed BMEP formula, this gives a figure of 395psi or 28.24Bar,
So, although my ram intake mods produce very good improvements above OEM, the BMEP calculations show that these improvements are realistic (from 15.14Bar to 16.2Bar) by comparison to the BMEP figure for Turbo charging (22.1Bar) and Supercharging (28.24Bar). What I find particularly interesting though, is how maintaining torque throughout the rev range has a considerable effect on HP.
This is all great stuff, and I can feel a PowerPoint presentation coming on to aid our sales effort Exdos... You are going to have to spend some time explaining it to me in words of one syllable though - right now I am understanding one word in 3 :D
I've been reading these posts, but not contributing because I got lost very early.
However, if you do produce repeatable results of 20-50bhp increases, and start offering them to forum members, then I'll happily put one through some extended testing for you :P
Bing, You're doing quite well if you're already achieving 33.33% success rate with your understanding of this subject. You need to get the Mrs and Wee Bing to give you CPR and blow up your nose (i.e. ram effect) to get more oxygen to your brain. I reckon this way it's theoretically possible to get that figure up to 100%, dependent upon the starting point of your OEM IQ and how much time you've spent in Bars. :wink:
I'm currently waiting on a professionally made part, and once that's fitted, I'll know where I stand on this because I'll be able to compare that with my "Blue Peter" style ramcharger which produced the results in the graph. I may well ask you to help. :thumbsup:
In large crayon font. I've made a few of those :D
I am seeing lots of simple pictures and graphs too - room to adapt the pitch :thumbsup:
Possibly a video to pad out the timing a bit. As a mentor once said, "PowerPoint; Made by people with no power who cannot make a point" :D
I like the video idea, works for a head to head vs. a stock ///M :thumbsup:
Agree with your mentor - if you have to use it, don't.
Thanks for that, I'll do some number crunching over the next week or so and see if I can provide any useful insight (unfortunately I don't have the luxury of retirement yet, so I don't have much spare time!).
Sorry for the delay in replying – rather a busy weekend ... ;)
exdos said:
tertius said:
I do agree that they are very close, but
a) I would much prefer to have a measured value for transmission losses rather than a guess;
Take a look at the thread comparing the S54 to the S65 here: http://www.bimmerboost.com/showthre...erview-history-comparison-and-power-potential the author states: “You may notice both motors follow the 15% drivetrain loss rule almost exactly.” Why should my Z4MC with the same S54 engine be much different?
I’d still prefer a measured value for each car, but fair enough – pretty lucky given I just guessed at 15% when I used it before ... ;)
exdos said:
tertius said:
b) From reading around it seems to be quite unusual for a standard S54 in a Z4M to actually meet or exceed the manufacturer figure, so you may have an exceptional engine or your method may be producing over-optimistic values
Au contraire. From my reading, it seems that BMW has managed to produce the S54 to very close tolerances and they all record very similar dyno figures to the published values for each different model the S54 engine is used. Only a few postings ago, Original Guvnor posted: “mine has recently been static dyno'd at 321bhp at 7300 rpm so I'd guess it will be near enough stock at 7900. It is also completely unmodified from factory as well.” Again, why should my Z4MC be much different?
I stand corrected.
exdos said:
tertius said:
The basis for challenge is simply that the results you are claiming are extraordinary and you seem unwilling to perform some more traditional/independent tests.
I will be more than happy to do such tests when I consider the time is right, and that’s when I’ve taken this project as far as I think it can be taken and I'm ready to patent or publish, and I’m not finished yet. As I’ve previously reported: “I've been in arguments/discussion in the past about the effectiveness of the ram-effect and originally got into datalogging to find out for myself what is actually happening inside the air-intake system. Some folk demand the proof and if you don't provide it, then you're damned, and when you do produce it, you're damned again.” It seems to becoming the case in this instance. Are you happy to pay all my costs for the tests you suggest?
Well if you will be paying me a suitable proportion of the profits from your invention, then yes, I’d be happy to consider funding the costs of the tests ... ;)
exdos said:
tertius said:
Additionally if we compare your “OEM” torque curve with other examples (e.g. here http://www.dyno-plot.co.uk/dyno/dynoplot/id%3D786%26but_sea%3Dqs%26frcd%3D161/BMW-Z4M.htm) you will see that your torques curve is unusually flat compared with the dyno-plot graph which drops off noticeably after the peak torque value. Now a flat torque is good, very good, but that difference does make me wonder if there is something odd about the way Dashdyno is estimating torque?
The reason why my DashDyno produces a flattish torque curve, is precisely the same reason I keep hammering the point that a static dyno cannot replicate the ram-effect. My DashDyno would produce the same flattish torque curve when hooked up to ALL Z4MCs being logged in real world conditions, where ram effect occurs, and not just mine. As I’ve said before, a 3rd gear run goes to speeds well above the speed of the fan used with most static dynos, consequently there is air-starvation of the Z4MC's OEM ram-intake on a dyno. In “real world” conditions the Z4MC OEM air-intake harnesses the ram effect, which maintains torque levels as does the Vanos system. Do you get how ram-intakes are supposed to work now?
OK, but this is really the crux of my challenge: you are showing a performance characteristic that can only be measured by the measuring system you are using, and cannot therefore, be confirmed by other, more widely used and, therefore, understood methods.
The scientist in me has to ask, “Is it a real characteristic, or is it an artefact of the measurement system?”
exdos said:
tertius said:
You are bouncing around the chart and picking numbers at different RPMs and then comparing them. Remember we are trying to compare the same fundamental engine here so in order to really see what the differences are we should try to compare at similar points iin the rev range.
I’m not bouncing around the chart at all; I’m simply quoting the actual maximum torque values at their respective rpms (ignoring the so-called “artefact”). I don't decide the rpms at which peak torque occurs, I've simply looked at the data and stated the rpm at which the highest torque value has occurred. Are you disputing those values? Look at the graph again and you should be able to see precisely those points on the three plots. If you don’t agree with the figures I’ve used, please can you tell me the values we should use?
tertius said:
My 30% increase came from comparing the stock engine at peak power - 7900 rpm; with a BMEP of 11.8 - to your engine at peak power - in your case 7800 rpm, i.e an almost identical engine speed, a BMEP of 15.8 (over 33% greater).
You explained that in your last post, so that's why I performed the calculations using BMEP at peak torque, and now I’ve demonstrated that the increase is 7%, and not 30% as you suggest. Now that I've worked to your method, you don't seem to like this by now claiming I’m “bouncing around the chart”, although you have conceded that my methodology is consistent. As I see this is another case of “Some folk demand the proof and if you don't provide it, then you're damned, and when you do produce it, you're damned again”. Déjà vu. :thumbsdown:
My apologies, I didn’t realise you wanted to exclude the “artefact” data above 7000-ish RPM; I was still looking at the complete graph which shows peak torque and peak power at 7800, hence wondering why you’d suddenly moved to 5400 rpm.
exdos said:
tertius said:
So not only have you increased peak torque value above the standard engine, you have kept the curve flat almost throughout the rev range AND shifted the point at which peak torque is made up the rev range, thus increasing the power output of the engine massively. And you did all this by just modifying the air intake.
Yes, but there’s a bit more to it than that. I could very easily tell you what I do, and then you’d easily see how this works, but because I’m still considering patenting my invention, I’m not willing to publicly divulge this information just yet, as I stated at the outset of this thread.
That is a very fair point and you certainly should not divulge anything that would put any future patent at risk.
exdos said:
tertius said:
By contrast your air intake work alone has increased peak power by nearly 27%!
I’ve explained previously how the spike in torque occurred in my ramcharger run, and the HP figure is solely a consequence of that. If you can find me any proper technical information about ram-intakes with lots of published data, I’d be obliged if you’d refer me to it. As it is, I consider that I'm in "unknown territory" but if you have better information to guide me, it would be most helpful. :thumbsup:
Just because that is how power is calculated doesn’t make that gain any less extraordinary – torque at revs is power and getting power is what every racing driver (and petrol head) wants. One way of looking at it is the area under the torque curve (a very powerful measure) – if your numbers are right then the increase in that area must be (relatively) massive and it would be a huge advantage to any race car/team.
Regarding ram intake data - this is part of the challenge you face, as you say there is very little data about ram charger effects on road cars, and what there is seems to be generally dismissive of whether it is real at road car speeds and the associated air pressures. As I am generally rather conservative I will tend to be sceptical of claims that are a long way out of the norm.
However, that also means that I’m not the person to actually make those conceptual leaps; but I can assure I would be delighted if you were proved correct, and I’ll be at the front of the queue to buy one.
I shall happily contain any concerns and wait until you are in a position to share more information. Though I'm still open to the deal I suggested above ... ;)
exdos said:
FYI, the BMW E87 I M has a published BMEP of 305.9psi = 22.1Bar so even with my ramcharger mod, I’m well away from mechanical forced induction figures with a BMW engine, so to me at least, my figures are realistic. <EDIT> A quick back of a fag packet calculation shows me that for my Z4MC to be able to achieve a BMEP of 22.1Bar, the MAF would have to record an airflow in the order of 48.5lbs/min, whereas, the highest figure I've seen to date is 33.4lbs/min. The absolute highest that I expect to see from a ram-intake is 35lbs/min with a rev limit set at OEM 8000rpm
I don’t know how realistic it is to compare absolute BMEP values between forced induction and NA engines; certainly I’ve read comments that comparison between spark ignition and compression ignition values is not really possible, so the same may apply.
No worries.
There are quite a number of different commercially available ECU dataloggers and software for laptops which connect to the OBDII socket and which do dyno runs in the same way that the DashDyno does; such as Dash Hawk, DashDaq, Scangauge. These things have been around for a number of years now. My car will show the same results with any of these devices (with the proviso that they use the same formulae to compute torque /HP) because they also use the data yielded by the car’s ECU.
With specific regard to what I have described as an “artefact” which shows a “blip" in the torque plot; this is not actually an artefact in the calculation of torque at that point on the rev range. What I am trying to express is that I didn’t maintain my foot to the floor to achieve WOT up to the redline, therefore the plot of torque that you see, shows that when I slightly lifted –off, the ram pressure instantly increased within the air-intake system, so that when I re-applied WOT, the engine was ingesting a greater mass of air than it would’ve otherwise done had I maintained WOT throughout. The DashDyno has faithfully recorded what has happened and the scientist in me interprets the plot as showing that my air-intake can provide a little “boost” in such a situation because it really is harnessing the ram-effect.
Accepted. If I’d maintained WOT throughout that run, as I’ve described above, the peak torque would still only have occurred at 5400rpm. This wouldn't affect the BMEP at peak torque, but it has affected the HP figure, and I agree that this is probably recorded greater than it would have been had the car ben driven at WOT throughout the run, and that IS an artefact. Having said that, the HP figure would still be very high.
I agree that the results do appear extraordinary, and it’s entirely due to this that I’ve been driven to investigate and develop my ideas, based entirely on my observations. Not only can I record and see these gains graphically, but I can also feel and see them when I’m driving my cars with my ramcharger mods. There is power available throughout the rev range and when you change up and accelerate there appears to be even more, because the engine revs have dropped and the ram pressure has increased.
That’s the problem; there is scant data on this, so the only way I’ve been able to get any, is collect my own, and this is where my DashDyno has been so useful to me. From the outset, I’ve been aware of the generally dismissive attitude to the usefulness of the ram-effect, but if it’s good enough for F1 cars, and they don’t spend all their time at 200mph either.
Surely the BMEP figure of the OEM S54 at 15.1 is comparable with the BMEP of the same engine with an Active Autowerke Supercharger kit which gives a figure of 28.24Bar? As we’ve calculated, my ramcharger increase the BMEP to just 16.2Bar, which is well short of that figure.
Well, I'm not sure about that.
I mean you can obviously compare them but drawing conclusions may be difficult. If you look for example here you'll see the comment, "It is worthwhile to note that a contemporary, normally-aspirated CI (compression-ignition) engine can easily make 15 bar of BMEP, and several turbocharged CI street engines routinely exceed 20.5 bar. It is helpful to remember that BMEP is a useful tool for comparing and evaluating similar types of engines."
And since BMEP is giving a measure of how efficiently an engine produces torque from capacity and forced induction is sort of an artificial way of increasing capacity it makes sense that the values aren't readily comparable.
A compression-ignition (CI) engine is a Diesel, whereas the S54 engine is petrol spark-ignition (SI), so you'd be comparing apples with oranges there.
My reference to BMEP is to compare the same S54 engine (SI) running with: 1.) a ram-air intake at 16.2 Bar and then with 2.) a supercharger when it operates at 28.24 Bar. To me, that's comparing apples with apples because the engine is the same and the only difference is the amount of air that you can stuff in it with a supercharger, which increases torque, hence it will increase the BMEP.
Yes I understand that. That quote was not meant to be exhaustive, my point was that a supercharged engine is not really a similar type of engine as a normally aspirated one. Taking the examples from the quote above: the forced induction CI engines are producing BMEPs more than 30% better than the NA CI engines but I don't think we could conclude from that that the NA versions are poorly designed would we?
What I take from that is that there are really four classes, which really need to be compared within their categories:
1. Spark ignition normally aspirated
2. Spark ignition forced induction;
3. Compression ignition normally aspirated
4. Compression ignition forced induction;
