Hi forum community,
I have a 2007 BMW Z4 E85 and have an issue where the car has a rough idle which sometimes leads to the car stalling when stopped.
I would say the issue is slightly worse after the car has warmed up.
Rough idle feels like the car is running a bit lumpy, and the idle can drop a bit lower and then this blips back but sometimes this will stall completely.
I have plugged in my fault code reader and attached the fault codes which are 29E7 and 29E8, fuel mixture adaptation.
Also, I have taken a couple of pictures in the engine bay which I think shows signs of the problem.. there appears to be an oil leak. I have read a couple of posts that this may be the idle valve. Has anyone else had this problem and replaced this part and fixed the issue?
I have had a look over the hoses and they appear to be in good condition which was the other fix mentioned. Any help is greatly appreciated
