Roof recolour
Zedebee
Veteran
 North Hampshire
Inspired by [ref]jock156[/ref]’s new blue roof, I decided to have a go at recolouring mine. However, being a cautious fellow, I am testing Furniture Clinic’s roof dye on some samples (kindly provided by Jock) first.
1. Start with roof sample (note white spot)
2. Wet it
3. Paint with dye
4. Dry with hairdryer
5. Apply second coat
6. Final compare
Verdict: this is supposed to be a “dark blue” dye. Coverage is excellent and even and the fabric looks much cleaner as a result, however under the kitchen lights it still looks black. Only when compared to the original you realise how un-black the native colour is and can get a sense of the blue.
I’ll definitely give it a go. It won’t be as good or as blue as Jock’s, but for an improvement on a budget it’s worth a try.
I’ll be really interested to see the outcome of your experiment. I have a good hood on my E85 Z but there is one 3cm round mark which I can’t seem to get rid of by cleaning. This sounds like a possible solution. I look forward to seeing how you get on.
The final results would depend on the starting color of the top if changing i suspect. For example, going from a black top to a lighter color. Possible would need several coats? However, good luck and will follow for any updates. This maybe a option for those of us with a good but faded top.
