My roof works, but it is really slow to start to open, you need to give it a push with your hand to get it going. Closes no problem at all, quite quick. Checked oil level, as pump had been moved into the boot, and this seemed fine, so after reading numerous posts on here, bit the bullet and brought a new pump and motor.
Yep, no difference, so one expensive mistake, but hey ho.
It unlocks fine before struggling to move.
Apart from the pump/motor, there doesn’t look much else to the system other than the rams. Could it be these failing?
Also, I can see the fitting for the release cable, but can see what it is, or should be, acting on.
Al
Al
