Beancounter1980
Active member
Hi Guys, are we sure the motor can be replaced under AUC?
Shipkiller said:NO BLEEDING IS NEEDED. It's self bleeding.
Are you sure you torqued the hydraulic lines properly. eg. tight enough?
If not, you COULD be getting air in the system and a couple of cycles bleeds out the air. AND you could have a small leak. The oil will come out the bottom drain system.
mwill195 said:Hi, sorry to hear you are having problems after replacing your motor. I did mine a couple of weeks ago, also a huge thanks to
shipkiller for his website, couldn't have done it without it.
When I bought my new motor from BMW I bought the 'hydraulic repair kit'. This contains new copper seals for the hydraulic
lines. It also includes the butyl cord to help seal the enclosure. It is worth replacing the seals. Sounds like you may not have tightened/sealed the system properly so the lines may be leaking hence the slow performance. Alternatively is your bypass
cable in the boot fully off?
FYI the hydraulic fluid from BMW is £15 a bottle!
Was your motor water damaged/wet? If so I hope you cleaned your drains thoroughly as well. Mine were both blocked!
Mark
this guys right I had my roof motor changed by these guys and they did an awesome job. For £140 I wouldn't recommend trying it yourself, I had mine off about 4 times it's easy to get off but such a pig to get back on, let someone do it who's got experience, these guys have done loads.mr h said:hi guys im new to the forum but have been helped by it befor and now its my turn to help u guys, iv posted in another disscoution myn went last week and got it sorted by a garage in walsall west mids called apac not an indipendent bmw, but my girlfriends dad uses them so iv used then 4 my problems abs fult and my roof they charged me £140 to change the motor and unblock the drain holes he says he done a few , if ur having problems call them on 01922 455 795
yes £140 is for the labour. Bear in mind it takes at least 4 hours and it's a specialist job trust me it's good! The roof pump I got for £265 plus vatEwazix said:mr h said:hi guys im new to the forum but have been helped by it befor and now its my turn to help u guys, iv posted in another disscoution myn went last week and got it sorted by a garage in walsall west mids called apac not an indipendent bmw, but my girlfriends dad uses them so iv used then 4 my problems abs fult and my roof they charged me £140 to change the motor and unblock the drain holes he says he done a few , if ur having problems call them on 01922 455 795
Motor supplied and fitted for £140 is this garage a registered charity? I thought the motor cost more than that without labour, it's a no brainer if it's correct :|
EdButler said:Hey all, I tried my roof this morning and nothing happened. Tried again 20 miles later and it worked fine, just a little noisier than usual I think. Anyone had problems in the cold or intermittent failure before it completely dies?!
JimmyPop said:Think my motor is buggered as well. When I press the button, the roof unlatches and motor continues to make a noise but doesn't move until I lightly thump it underneath. It then continues to open without a problem and closes without any intervention. I'm going to try to move it manually and oil the latches/hinges tonight to see if that loosens things up. Even if it doesn't it's not too much of a worry - thankfully its a BMW AUC (bought in April) so will be covered by warranty.
Only problem is I'll miss having it for this lovely weather!![]()
oli445 said:JimmyPop said:Think my motor is buggered as well. When I press the button, the roof unlatches and motor continues to make a noise but doesn't move until I lightly thump it underneath. It then continues to open without a problem and closes without any intervention. I'm going to try to move it manually and oil the latches/hinges tonight to see if that loosens things up. Even if it doesn't it's not too much of a worry - thankfully its a BMW AUC (bought in April) so will be covered by warranty.
I have exactly the same problem, did you need a new motor in the end? Or does anybody know if this is a sign its on its way out?
