Scretching my head, roof won’t open past 'service mode' step. Cowl opens, roof folds and unlocks but won’t go down to the trunk. No error codes. It says Locking procedure not completed, check for obstructions, but there's none. Once in a while I get A689 Hall Sensor Roof Pack Erected and A693 Micro Switch Roof Pack Stowed, but it’s not consistent and always history codes. If I release pressure screws on hydraulic unit, I can manually fold roof, but not to the very end, I still cannot close trunk completely, like there's 3-5cm gap remains. Then if I tighten screws if closes back easily from the button. Then won’t open completely. If I open and it gets stuck but I keep pressing open button, hydraulic motor works but it does not go down. If I do this many times the middle motor (on that side with 3 of them) gets pretty warm. I still can close it fine after it gets stuck on opening phase. All relays and valves work fine according to Live Data. Hall Sensor Roof Pack sits on open all the time as far as Live Data says. Micro Switch Roof Pack Stowed I just can’t locate. Anyone had similar issues fixed?
