Hi all,
Seems the curse has struck and I’m struggling to fix it!
When i press the open button the electric latching motor unlocks the roof, hydraulic motor switches on for a brief second but the roof doesn’t move. Then the light in the centre console flashes red and no movement from there. I have to manually relatch the roof (although if I start the process manually sometimes it will re latch from pressing the close button).
What I’ve done so far:
So I’m slightly stumped, does anybody have any idea? Issues started after leaving the boot slightly opened, so was wet although dried out when I noticed (may be red herring!)
I’ve got a creator 310+ code reader, but not fully sure what menus/sections/sensors I should be looking at to try to diagnose, I’ve got a number of photos before during & after pressing the open button of screen but I have plenty more of the other screens before/after if useful (different menu sections, will attach in second post) - hope they may be useful for those more technically minded than me!
Really appreciate any help, have parents tools and garage until Monday, so happy to try any ideas from the experts!
Happy new year all! Harry
Loom
Boot micro switch
Data stream from code reader
Before
During
After
- Taken the car to bigwinn (very grateful for all the help so far - thank you!!!) to check the motor (relocated by previous owner) - believe motor is good, and as fires up initially and showed intermittent signal to fire, we thought it was wiring/sensor issue.
- Checked the loom above passenger window (stripped back armour cabling) and found no breaks/nicks in the accessible section, see photos
- Cycled the roof a few times manually, roof won’t close from the button when manually opened, no lights no movement - only ever get action from fully closed position
- Checked the micro switch for parcel shelf, also looked fine and light was red rather than orange, however when reading the data stream on code reader, boot shelf switches from “bottom” to “not at bottom” after unlatching, but we could see it working on screen as we toggled manually.
Loom
Boot micro switch
Before
During
After
