Afternoon-
All roof specialists/Number 5...
Let me describe the issues and see if anything sticks
Roof was fine on the car when I got it.
Fitted gap tech module and the battery died- initially I put faults down to a low battery.
But they persisted so I took the gap tech off to see if that was the issue- it wasnt
I relocated the motor to the boot- issue prevails the same... so not associated I don't think.
I've stripped and serviced the boot position switch and had the parcel shelf out to see if thats the issue- I don't think it is
If I reset/disconnect the battery and start from scratch:
No lights or issues.
Roof will unlatch, motor kicks in and it will lower the roof all the way
Doing it back up, roof will raise probably 75% of the way then stops- no motor or noise etc. TOP RED LIGHT on switch constantly blinks.
To re secure I can move the roof to the windscreen and can close using the allen key
I'm thinking a position sensor issue?
Also I noticed this earlier and it doesn't look right, someone has had the cover off and I am not sure what that bent piece of metal is?
Over to you guys...!
