So.. Your saying its OK and nothing to be concerned about?
I will get the kettle on it tomorrow
im torn between what seems not quite right and a bloody good idea, but what is involved ? gimme 1-5 spanners in difficulty idea ..Jembo said:So swapping the roof over from your 2.0 before u sell it is not an option?
i seem to have one each side same dimensions on the other side, strange, same distance from the front, same distance in from the edge, asymmetrically identicalfirebobby said:Apart from the fag burn, the rest is OK by the look of it. The drainage holes are meant to be there![]()
A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back onroad warrior said:im torn between what seems not quite right and a bloody good idea, but what is involved ? gimme 1-5 spanners in difficulty idea ..Jembo said:So swapping the roof over from your 2.0 before u sell it is not an option?
Or more of a 2.5Jollyjoiner said:A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back onroad warrior said:im torn between what seems not quite right and a bloody good idea, but what is involved ? gimme 1-5 spanners in difficulty idea ..Jembo said:So swapping the roof over from your 2.0 before u sell it is not an option?
Jollyjoiner said:Or more of a 2.5Jollyjoiner said:A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back onroad warrior said:im torn between what seems not quite right and a bloody good idea, but what is involved ? gimme 1-5 spanners in difficulty idea ..![]()
so a five then cus its a swap and 2 cars involvedJollyjoiner said:Or more of a 2.5Jollyjoiner said:A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back onroad warrior said:im torn between what seems not quite right and a bloody good idea, but what is involved ? gimme 1-5 spanners in difficulty idea ..![]()
Nooo still a 2.5 to 3 but twice as longroad warrior said:Jollyjoiner said:Or more of a 2.5Jollyjoiner said:A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back on
so a five then cus its a swap and 2 cars involvedJollyjoiner said:Or more of a 2.5Jollyjoiner said:A 3 in spanner rating I would say and two people is better than one for lifting roof off and then putting back on![]()
No I'm guessing the pictures might have been put on using photobucket and that stopped working when they made you pay for itroad warrior said:btw, i found a write up on here but i noticed i cant see the pics.. do i need to turn something on in my profile maybe ?
ahh, or in this case its a fella called shippkiller back in 2009 who put it on his website that aint here no more - but good thinkling batmanJollyjoiner said:No I'm guessing the pictures might have been put on using photobucket and that stopped working when they made you pay for itroad warrior said:btw, i found a write up on here but i noticed i cant see the pics.. do i need to turn something on in my profile maybe ?
Smartbear said:I used net curtain wire, it’s a bit fiddly though!![]()
road warrior said:I had a thought. Testing for clogged drain holes by pouring water in is rather like sticking your finger in a light socket to see if the fuse has gone. So I wondered if blasting it with a powerful wet/dry might be better, and how do you clean it anyway?
