Ed Doe said:Welcome!
I'd give Mr Vanos (Steve) a call if I were you - he's based up north and does fantastic work. He's not the easiest to get hold of and is quite booked up but worth the wait imo.
Cheers Ed thanks for info wasn’t sure if he did rod bearings
Also sorry but the pedant in me can't leave it - it's 'Peace of mind'![]()
Mr Tidy said:40K is pretty early to get them done but assuming you don't know the car's history and given that it is well over 10 years old it probably makes sense for a keeper, and that way you know where you are starting from.
My car had done 78K when I bought it but had 7 previous keepers so I got them replaced at 78K - and was glad I did!
We'd love to see a photo or two of your car.![]()
Thanks for info will give him a shoutDave1971 said:I use a guy in Newcastle called Dean. He’s an BMW trained master tech who’s got an excellent reputation for his work. His labour rate is very good (personally I think he doesn’t charge enough given the quality of his work) and he doesn’t “up sell” and do work that’s not required.
https://www.dwmotorworks.co.uk/
I would echo what srhutch has said and say 40k is very early for rod bearings.
srhutch said:40k is very early. I plan on getting mine done around 70k as recommended by my Indy. Even then I’m not really sure they will need doing given how I drive it. Be another 8 years or so though so not worrying about it for now.
It’s got a full documented service history and paperworkArgenta said:With the amount of tinkered-odometer M's out there I'd say you'd be very sure about the cars history, to be sure of those 40k miles!![]()
That’s my thinking as wellcraig3.2 said:srhutch said:40k is very early. I plan on getting mine done around 70k as recommended by my Indy. Even then I’m not really sure they will need doing given how I drive it. Be another 8 years or so though so not worrying about it for now.
I thought the same,Steve....
Until I decided to just get them done while it was in fir other stuff early this year,and at 61k miles,approx, they were just about worn through,and would have been lucky if I had got another 2-3000 miles out them before they spun a bearing.
And mine has been warmed up properly before going above 2.5/3k rpm and regular services, additional oil changes etc.,since I bought it in 2012, and with barely 20k miles on it at the time.
I was surprised just how bad a few of mine were.
Definitely worth getting done op.
Glad I got it done.
Skye 1872 said:Car has had 3 previous owners and the last 2 were members on here so it’s just for piece of mind since it’s a keeper and a really nice example
Nick W said:Had mine done at 85k and they looked almost as good as new. Had mounts etc done at the same time to merge the costs, even though they looked in good condition. At that mileage I think it was money well spent because it's a couple less things to think about when I turn the key in or hit the noise pedal but at 40k for the same peace of mind and a lot less money I'd have an oil analysis.
Skye 1872 said:Lot of good information and advice appreciated but still going down the replacement route
What’s the risks involved any advice appreciatedabar121 said:Skye 1872 said:Lot of good information and advice appreciated but still going down the replacement route
That's your choice. Just remember that replacing them isn't exactly risk free. I would go for oil analysis if you are paranoid and wait until it hits double the mileage.
You pays your money..
Skye 1872 said:What’s the risks involved any advice appreciatedabar121 said:Skye 1872 said:Lot of good information and advice appreciated but still going down the replacement route
