Retrofit Cruise Control Diagnostics
Moose94
 Rugby
Hi All,
2006 (56) 3.0 SI Manual E85
Fitted the retrofit cruise control stalk+harness direct from BMW last night.
Harness connected to the headlight switch on Purple/Violet and Black/Brown. Blue harness ran all the way to the glovebox area, into the engine bay and into the 4th pin in on the Black DME connector in the junction box.
Cruise isnt working.
Any ideas what i can do to rule out any specifics on whats gone wrong?
Thoughts are 12v isnt coming into the switch, how would i test that, via the headlight switch, lights working/not?
Clutch position switch, from what i can gather does this only control the cruise on/off or should there be a rev function on clutch depress when on idle? Any other way of testing, car turns on without any pedals depressed but seems that is the norm.
Brake switch, brakes seem to work fine and no warnings or errors flagged on my obd2 reader.
BMW instructions state to update the ISSS module but reading online nobody seems to have needed to code it.
TIA
That I can think of, there are three things needed for the cruise to work:
- the correct signal from the brake light switch (brakes off)
- the correct signal from the clutch switch (clutch pedal up)
- a signal from the cruise control stalk
ISTA will not show you the stalk position, but if you use INPA you can read the status of the clutch and brake light switch, along with the position of the stalk (i.e. resume, cancel/accel/decel).
If you have access to INPA, I would connect it up, and read those values to find which isn't working.
Re check the light connections there are multiple colours similar
Best to go off the actual pins instead of colours on the lcm
Is there a way of checking the pedal switches are operating correctly without inpa?
Brake lights will be easy (and you've done those already). The clutch switch - maybe with a mutlimeter? It's probably a hall sensor, so I don't know how easy that will be to test in situ.
It’s a right faff to get too so a multimeter might be tricky.
I’ll see if I can get a new switch and return it if it doesn’t fix the issue atleast.
Honestly, you'd be better off spending the £20 on a usb cable to get the diagnostic software IMO.
The cable will be useful in the future, and will help pin point the issue, rather than struggling in a contorted foot well for potentially no gain
Needs a Windows laptop
Pretty sure I’ve a cable at home, just never managed to find a copy of inpa that wasn’t going to brick my laptop
