Hi All,
2006 (56) 3.0 SI Manual E85
Fitted the retrofit cruise control stalk+harness direct from BMW last night.
Harness connected to the headlight switch on Purple/Violet and Black/Brown. Blue harness ran all the way to the glovebox area, into the engine bay and into the 4th pin in on the Black DME connector in the junction box.
Cruise isnt working.
Any ideas what i can do to rule out any specifics on whats gone wrong?
Thoughts are 12v isnt coming into the switch, how would i test that, via the headlight switch, lights working/not?
Clutch position switch, from what i can gather does this only control the cruise on/off or should there be a rev function on clutch depress when on idle? Any other way of testing, car turns on without any pedals depressed but seems that is the norm.
Brake switch, brakes seem to work fine and no warnings or errors flagged on my obd2 reader.
BMW instructions state to update the ISSS module but reading online nobody seems to have needed to code it.
TIA
TIA
