I go for how the car feels and mine feels better with lower pressures, I think 34/35 fronts and 36/37 rears. I'm running Kuhmo's
sachb said:at the risk of opening up another can of worms should the tyre pressures be the same as the runflats? In my own humble opinion Michelins are the best for me and my car, feels much better!
N4LLY said:Blackcircles quoting today 4 x Pilot sport 4s's @ £ 774.48 fitted.
Is that a good price ?
225 / 35 R19
255 / 30 R19
N4LLY said:Cheers Andy.
Promocodes seems to crop now and then, do they actually work or do they inflat (Pun intended) prices prior to the promo ?
Argyll Andy said:N4LLY said:Cheers Andy.
The discount was applied automatically on ATS site, I didn’t have to use a promo code for the screenshot you see. As shown to you it’s £100 cheaper than Black Circles, without the ATS automatic discount still £50 cheaper than BC and IF, and that’s IF the Quidco casback works another £30ish off so ATS, with Quidco could workout total cost approx £640.
Bottom line buy those off ATS online today and the most you’ll pay is £673.96
For transparency BC also offering 2% cash back via Quidco. Quidco can be hit or miss, more hit in my experience![]()
N4LLY said:Argyll Andy said:N4LLY said:Cheers Andy.
Cheers Andy, I have an ATS less than half a mile away. I'll check it out.![]()
Smartbear said:sachb said:thanks for the comments/suggestions, am still to make up my mind between not run flats and expensive run flats, between comfort, better grip and cheaper ....and the security of the run flats...... whats my plan for a flat with a not run flat tyre with no space for a spare ? hmmmm havent had a flat for a long time!!? What are your thoughts? Do any of you who have ditched the run flats have a back up plan for a flat tyre?
Yep, rats tails![]()
MACK said:Smartbear said:sachb said:thanks for the comments/suggestions, am still to make up my mind between not run flats and expensive run flats, between comfort, better grip and cheaper ....and the security of the run flats...... whats my plan for a flat with a not run flat tyre with no space for a spare ? hmmmm havent had a flat for a long time!!? What are your thoughts? Do any of you who have ditched the run flats have a back up plan for a flat tyre?
Hi,
I'm considering switching to rats tails as some of my cans of Holts tyre weld are now nearly out of date. They're not something I'd ever come across before reading this thread. Are these a permanent or temporary fix?
It's interesting that your chosen Front pressure is BMW's recommended, but your Rear is more than 12% below. That's quite a lot.Lazza said:As far as pressures go, try different pressures out yourself.
Like many in here who have actually tried different pressures, I have settled in much lower than standard RF pressures. I’m using F36 R38 at the moment. At RF pressures it felt like it was skipping across the road too much and losing grip, especially on wet roads, on bumpy corners. At lower pressures there was too much movement from the tyres. As it is now feels spot on. That’s with Uniroyal Rainsport 3. As pointed out above, they aren’t the very best tyre but they are soo much better in every way than the Bridgestone RFs they replaced!
My background is from over 20 years driving MX5s on the road and on track so I have become quite good at reading what my tyres are doing :wink:
Apparently we are both 'snobs' !!!!!maxman said:Michelin PS4sStick to the road like glue.
I have one of these, you will need two bottles for a 255 tyre...Silverstar said:Something like this will do the job:
We are what we aremcbutler said:Apparently we are both 'snobs' !!!!!maxman said:Michelin PS4sStick to the road like glue.
And proud (and right of coursemaxman said:We are what we aremcbutler said:Apparently we are both 'snobs' !!!!!maxman said:Michelin PS4sStick to the road like glue.
mcbutler said:I have one of these, you will need two bottles for a 255 tyre...Silverstar said:Something like this will do the job:
I omitted quite an important detail. The fronts are still The Uniroyal Rainsports 3 whereas the rears are Goodyear F1 Asy. The RS3 definitely need a bit of extra pressure to stop them feeling floppy whereas the F1s don’t need to be so high. When I get F1s (or MPS4) on the fronts I’ll be able to drop them to a reasonable level too, hopefully closer to about 34psi.Busterboo said:It's interesting that your chosen Front pressure is BMW's recommended, but your Rear is more than 12% below. That's quite a lot.
