paddy wright said:If take the steering wheel off be sure to disconnect the battery for 15 mins before hand to avoid airbag code
Not really.Dr. Zed said:paddy wright said:If take the steering wheel off be sure to disconnect the battery for 15 mins before hand to avoid airbag code
Yup, noted!
My main concern is related to messing with the steering wheel position.
I've heard that the 'neutral' position can sometimes get messed up.
OK, I think you probably do need the wheel off for access.enuff_zed said:I'm not sure you need the wheel off anyway.
If you remove the column shroud it should be straightforward to remove the switch.
