Replaced Stereo - no FM radio reception
Z3_Rosco
I've replaced the factory stereo with a Blaupunkt unit. The sound quality is night and day, but I get no radio signal.
When I stick the OEM radio back in, radio reception is perfect. This rules out a problem with the antenna.
I've replaced the adapter that takes the Fakra connection and changes it to DIN, and borrowed a known good cable so I'm pretty sure it's not a cable problem.
I've stuck in a Pioneer unit from another car where the radio reception in perfect - same issue. So that rules out a faulty stereo.
So what now..... I must be doing something wrong. Does anyone have any ideas?
I do wonder if the OEM radio provide power through the Fakra connection to the antenna. (I imagine I could compare using a simple volt meter and see what the difference is).
(I could stick a DAB antenna on the windscreen but this feels like a cop out, and doesnt really give me what I want).
Any help, thought or guidance would be gratefully received.
So what is not working?
FM reception , DAB reception AM reception ?
Theres no FM radio reception. I haven’t tried AM and have no DAB antenna.
When searching for stations on the stereo, no stations are found. When manually seeking frequencies I can hear the stations in the background of the noise.
There's a DC feed from the OE head unit to the diversity box that integrates all the FM aerials
13 E Aerial switching signal Aerial amplifier or aerial diversity 0.5 Wht
Looks like I need to make sure PIN13 is supplying a 12v feed.
Will rummage tomorrow
