Red oil light on idle
darich
 South Lanarkshire
Hi all
After using the car for a while today, I was getting red oil light on idle.
As soon as revs reach around 900-950, oil light goes out.
Oil level is at max and unchanged since service a few months ago.
Car is a 2007 e86 3.0si with fsh and 78k miles. Running fine.
Is oil pressure sensor the most likely culprit?
Easy change
Thanks!!
Mike6 said:
I would guess oil pressure switch.
Thanks...had a similar answer from a knowledgeable mate who had an M3 for years.
I'll get my brother in law mechanic to have a look :thumbsup:
Not actually the same car, but I had this exact issue on a mini R52. Was the oil pressure switch, very simple fix (on that car at least)
