Rear Light Facelift Update Cheap How to
Great addition nahodo to the thread! Now there is even less messing around for anyone else who tries this! I really do think it makes the rear of the Z4 a lot more fresh looking and wider but each to his own. I still have not decided what to do with my front bumper when i do my angel eye mod and clear lights like CJ. I have sourced some pefect 80mm LED rings that are a bright perfect white and its hard to tell they are a ring made up of LED's I just need some time now to get it all fitted.
Your car looks great... Now there are 2 Sterling Grey 3.0 cars with updated rear lights in the world :-) Excellent stuff! :thumbsup:
One piece of advice i can give to anyone else... be very careful when positioning the new lights, one of mine was too low (by a few mm) play in the bolt holes and it has rubbed paint a little of the bumper. I can only notice it but its annoying all the same! The updated rears have sharp edges around the light so a small gap needs to be seen right the way around the light.
I also like your clear third brake light... updates the look further I may have to buy one as mine is cracked at the edge!
ZED_NOT_ZEE said:
Thanks nahodo. Do you need a GT1 to reprogram the LCM?
I'd like to do this project too... found someone who crashed their Z4 Coupe and is parting it out. Could take the whole rear end from them.
Also for the rusting rebar in the original pictures. A good sanding, then coat it with truck bed liner, or waterproof wheel well liner, let it harden over night. Then remount the bumper.
what the hell is a GT1? :-)
mine is only a 2.5i, but it looks faster :-) I really like sterling grey with the new tail lights. I also tried the red break light but i prefer the clear ones... looks bit cleaner.
Ok.. Everything else is almost clear, but how exactly i deactivate checkcontrols? I tired to search and google, but with no luck :(
I'm going to do this mod soon also..
cj10jeeper said:
Welcome onto the forum.
Great write up photos and explanations behind the work. I read it with great interest (even though I have no intention of ever fitting facelift (just prefer 4 white spot).
I'm sure the Ebay price of facelift lights is about to take a quick hike :)
x2.
I prefer the "clean design" look of the 4 clear spots, IMIO the facelift rears are literally putting square pegs in a round hole, change for changes sake.
:fuelfire:
x2.
:fuelfire:
well, i fully disagree - the facelift tail lights fit perfect to the character of the z4 - clean and sharp. well, still happy that I did it :-)
Hi nahodo.
Cant you tell me what KALTUEBERWACHUNG/WARMUEBERWACHUNG lines i have to disable to prevent the bulb error message from dashboard?
It's
WARMUEBERWACHUNG_RL_LI
WARMUEBERWACHUNG_RL_RE
KALTUEBERWACHUNG_RL_RE
KALTUEBERWACHUNG_RL_LI
CC_RUECKLICHT_LINKS
CC_RUECKLICHT_RECHTS
to deactive the checkcontrol.
cheers
nam
nahodo said:
hi all,
may i just introduce myself briefly - I'm Nam and I'm a happy Z4 owner coming from Germany. I was very impressed when I found this article because I was very keen to upgrade my prefacelift z4 with the new tail lights.
without your post i haven't tacled this project because on the german z4 pages i just read several times that you need the light control module from facelift which is very expensive.
just to contribute. i found elegant solutions for your issues:
1. the tail lights and break light is on
well, to prevent the "t" effect, you just have to code your light control module - in german the code is:
BREMSLICHT_ALS_STANDLICHT
nicht_aktiv
this means the breaklight should not longer work as your side markers and then they are off. everything works as intended (break, tail light..)
2. flickering of taillight / 6V issue
well, you took the power of the light of your plate sign - you can also program your light control module as follows:
PWM_ANSTEUERUNG_SL_RE_HI
wert_01
PWM_ANSTEUERUNG_SL_LI_HI
wert_01
this gives 12v to the tail lights without further modications.
this works out perfectly with my 2003 Z4 - hence no really need to buy the new light control module.
3. bulbs in the cockpit / dashboard
just deactive the checkcontrols and everything is fine.
this week, i bring my new bumper to the body shop and then i can finalize my project :-)
thanks for your great post!
cheers Nam
Hi Nam,
I just wanted to clarify. On point #2, does changing the value from the default of 02 to a new value of 01 send a 12v signal to the taillight pin? Hence no need to tap the license plate lamp for 12v. No wire cutting, splicing, soldering involved? just swap the pins?
Thanx!
hi threeoz,
yes, confirmed, needless to use the plate lamp wiring.
very clean and quick solution!
cheers
nam
nahodo said:
hi threeoz,
cheers
nam
You are absolutely brilliant. Thank you for discovering this elegant solution in the LSZ coding. I'll be using Autologic for coding.
I am 4 to 6 weeks away from completeting the facelift and buttlift of my 2003.
Aerokit front bumper cover.
Inexpensive, highly criticized Taiwanese headlamp replacements (OEM and Tekcarbon units are ridiculously expensive)
Hamann rear spoiler (subsidized by headlamp savings)
+2006 rear lights and bumper cover.
I'll try to document this and hopefully create the definitve upgrade guide. The fact that we can eliminate the need for wire splicing, resistors, and LSZ module replacement negates all previously believed upgrade paths.
Well done!
ThreeOZ said:
nahodo said:
hi threeoz,
cheers
nam
Well done!
hey, I'm happy to foster your upgrade :-)
curious to see pictures from you retrofit project(s).
well, now I have the front and butt upgraded to facelift :-)
komec said:
Thanks!
That was the last thing i needed to know. now i just need to start ordering parts :thumbsup:
That has been the hardest part for me. Parts are on backorder here in the US. Got some deals on ebay, but most parts have to come from the factory.
I ordered bumper and lights from ebay, no problems there. Now i need to get frame surrounds and plastic boot panel from stealer and im good to go :happyclap:
I was able to get a bumper cover on ebay for $65 USD with $60 USD shipping. List price was $520 USD with $175 USD shipping so I saved a huge amount of money. I also found a perfect right taillight for $145 USD. Could not find a left taillight so I spent $226 USD for a new one.
Can someone tell me what is the correct partnumber for tail light frame surrounds and that plastic boot panel? i tried to check realoem but cant be entirely sure what parts they are.
