B Brianpg0 Member Feb 3, 2026 #1 I have an 2011 E89 and every time I hit a pothole the read of the car seems to wobble and I think it's getting slightly worse. Has anyone else experienced the same problem and if so how to fix the it?
B21 Elite Scottish Borders Feb 3, 2026 #2 On E89s usually it’s some combination of.. Worn rear trailing arm bushes Worn bushes on rear knuckle links Worn shock absorber Shot tyres / incorrect pressure setting ARB link bushes /drop link failure In that priority Would help to state which model, mileage, year for us lacking clairvoyancey…
Chippie Veteran Wakefield Feb 3, 2026 #3 What tyre pressures are you running and are they run flat tyres or not?
B Brianpg0 Member Feb 10, 2026 #4 Tyre pressure is 2.4 bar running Yokohama Advans not run flats. Year 2011 E89 2.5 sDrive23i.
Chippie Veteran Wakefield Feb 10, 2026 #5 Non run flats at that pressure should give a good ride, perhaps the dampers are past their best, what’s the mileage? Do you have any record of them being changed?
F flybobbie Elite Stourbridge Feb 12, 2026 #6 My cars stock rear dampers were duff at 50k miles. Just fit some Bilstein B4, do the job. Bilstein B4 Rear (19-183916) - BMW Z4 E89 Bilstein B4 Rear (19-183916) - BMW Z4 E89 - Quality Bilstein product designed for automotive performance and enthusiast appeal. www.bilsteinsuspensionstore.co.uk
F flybobbie Elite Stourbridge Feb 12, 2026 #7 Of course obvious answer is....don't hit pot hole. Tell me about it.
