Re-size avatar help !
metal licker, if you want you can send me the picture you want resized in a PM or via e-mail and I will take care of it for you....
Done and returned by PM...
KERMIT1970 said:
WLH any chance you could resize a photo of my car for my avatar ? Cheers
Sure, just send it to me in a PM or post it.
Here are the requirements:
Maximum dimensions; width: 120 pixels, height: 120 pixels, file size: 11.86 KiB.
I joined today (LO) and has same problems but managed it in the end by doing the following:
Select the photo you want from your windows picture gallery - right click and select resize - select custom and then put in 120 as the size and apply. When you now go into edit your avatar in user CP, browse for the picture you've selected and changed as above and it should load up.
Good luck.
Good luck.
Yes, most of the time that will work. If it does not work the problem is the file size and that requires some image compression which requires either something like Photoshop or an online service that will do that.
