nimblemotors
New member
I just purchased a 2003 Z4 for my wife. She just loves it, and thinks I'm the best.
However, the radio volume control knob was not working. I did some searching and didn't find anything specific to the Z4,
so maybe this isn't a common problem? In any case, I took the radio apart and there is a little circuit board with the volume control knob.
I tried to find a part number, but not luck, but found the manufacturer name, and then scoured its catalog to find a picture that matched.
No luck there, but I did determine it is a digital control, and guessed it was an EC11 model, and found some on ebay that looked the same,
so ordered them and then I replaced the control on the circuit board, put it all back together, and now the radio volume works great.
Here is the ebay item, if it is no longer valid, just search for the same thing and hopefully you will find it. The adjustment rod is a little longer than the factory one, I didn't bother to cut it down about a 1/4 inch, it doesn't look 'perfect', but nobody would notice the knobs sticks out a little more than factory unless you told them..
https://www.ebay.com/itm/371842294877
Hope this helps the next person doing a search, since i didn't find anything in my search.
Now it is on to fixing the cup holders, might do another post for that if my search doesn't find the answers.
