Robsterrob
Has anyone here installed a racechip GTS into a 20i? (Or any other variant). I’m thinking about it…wondered what other’s opinions and thoughts are.
Russ Z4 said:Thats about it. The logging will show up the differences in the boost and the flashing of the ECU will increment a count and parity that will not match the count held by BMW. So in short, bye bye drive train warranty.
OK, to clarify my lazy English.B21 said:ECU is not flashed when using a tuning box![]()
Russ Z4 said:OK, to clarify my lazy English.B21 said:ECU is not flashed when using a tuning box![]()
Either you have bogus boost values if you are conning the ECU with a tuning box - which is a dead give away you've strapped on a tuning box, or there will be a mismatch with BMW's held figures and whats on the ECU (even if you return the ECU map to stock) if you go down the flashing the ECU route.
