nichollsz4
Hi all,
Not sure if I'm posting in the right place, so please point me in the right place if this is the wrong place.
I have a "few" questions on my Z4 I recently purchased...
1. My passenger window doesn't automatically go up. Is this the same for all? The switch seems to indicate it will with a two click.
2. How do you make the roof and window go down and up off the key. Seen some with this option and wonder.
3. The roof is working fine at the moment but i noticed the other day once the motor cuts off you can hear the motor clicking as it slows down. Is this something i should worry about?
4. The roof lining on the inside seems to sag a little on both sides. The pics show whatnot looks like and what I think it looks like
And last but not least number 5.
The clip at the top of the rear centre console will not full retract to it's normal position (see pic). I cleared something metal that seemed to stop it, but still doesn't go all the way up. How do you fix or replace.
It's amazing what you miss out when you buy a car and when you clean it for the first time!
Oh and it's a 2003 soft top, if that helps.
Advice would be greatly appreciated.
Thanks,
Thanks,
