Harry_E89 said:At 60k miles it looks like my shocks are leaking.
They are adaptive shocks but I'm thinking about going with Bilstein shocks and coding out any errors.
Should I also replace the springs? What's the normal life on springs?
After 40k miles the adaptive shocks leak and become useless.javis20 said:Are you sure the shocks are leaking? Sometimes garages squirt oil on shocks to trick you into replacing them. I've had that happen multiple times here in the US. In fact the BMW dealer told me my left front shock was leaking. I went home and cleaned and dried the shock and it never leaked another drop.
Just my opinion. If it's really leaking, I would stick with the adaptive shocks. Especially if you use it as a daily.
First time I’ve ever heard of this. It’d be good to know which garages have done that to you, so the rest of us can avoid them.javis20 said:Sometimes garages squirt oil on shocks to trick you into replacing them. I've had that happen multiple times here in the US.
In the end he charged me £170 a corner, did it in a 2 week turn around, sent the old ones back in the same packaging that they came in, and had my garage fit them. The car feels much better on the refurbed shocks.B21 said:Beeacon said:B21 said:HI, yes I spoke to the chap, 07877 453936
He wanted £280 each or £260 for 4 at the same time, but he couldn't do the rears anyway..my two rear 35is dampers appear to be non misting / non leaking if you wanted to buy them, Im about to put a lot of old N20 /20i /redundany 35is bits on eBay..![]()
Unfortunately it is the fronts on mine, rears are holding up well. Thanks for the contact info, very handy to have!
Cheers,
Beeacon.
R.E92 said:Is it possible to set the KW V3 or Ohlins to stock ride height?
I'm not in the market for new shocks at the moment but if the fronts start to leak again I might be tempted. I wouldn't want to run any more of a drop than the current adaptive setup though as it would probably cause rub with my wheels.
Jollyjoiner said:I've just had fitted some Bilstein B8's front and B6's on the rear of my 35i. The reason I've had the 6's on the rear is because I ordered the B8 rears in January and had kept being told they are on back order and Bilstein then said end of September but not guaranteed. They then told me I could use the 6 as the damping is the same as the 8's, it's just the 8's are 20mm shorter. I had already put some Eibach pro springs on the standard dampers so had these transferred to the Bilsteins. This setup has made the car very slightly firmer but not harsh and the car is now less crashy over rough tarmac. It's a combination that many a dealer/garage say is a good combo for fast road and the odd trackday.
The ride hight looks the same with these new Bilsteins as it did with the original dampers as it's still on the same Eibach springs, I believe the drop from when it had the original springs was 20mm front and about 10mm rearB21 said:Jollyjoiner said:I've just had fitted some Bilstein B8's front and B6's on the rear of my 35i. The reason I've had the 6's on the rear is because I ordered the B8 rears in January and had kept being told they are on back order and Bilstein then said end of September but not guaranteed. They then told me I could use the 6 as the damping is the same as the 8's, it's just the 8's are 20mm shorter. I had already put some Eibach pro springs on the standard dampers so had these transferred to the Bilsteins. This setup has made the car very slightly firmer but not harsh and the car is now less crashy over rough tarmac. It's a combination that many a dealer/garage say is a good combo for fast road and the odd trackday.
Interesting…so given all the changes what do you think your ride heights are now front and rear relative to stock?
