Same symptoms that we had at the weekend.
I think once the hubs are cleaned and timing re set you shouldn’t have any other issues.
It’s hard to say if it will happen again. You’ve clean all the solenoids and check valves. Oil flush and then oil and filter change and it should be good.
Do able at home with the correct timing info and tools.
