Finally! A little bit of progress. Managed to dive into the car between showers and found a few interesting things.
I'll group all the photos at the bottom for reference.
All taken from BMW Scanner 1.4.
Firstly, no surprises with the car itself. Information is stored in both the Instrument Cluster (IKE) and the Light Control Module (LCM)
These tally. There is nearly always a small discrepancy in mileage for some reason.
Ran a full system scan which of course threw up a load of historical stuff too.
There were codes for the vanos solenoids. These cleared and the engine light went out.
The DSC initially couldn't be found (unknown) however with the engine running it appeared and had codes including one for faulty pump.
I was able to clear these and all the trifecta went out! I was not convinced it was cured though.
In discussion with Stuart (bigwinn) he sent a link to 'quick fixes' for the DSC pump, including 'percussive adjustment'. :?
Not got to that extreme yet.
However it also said that the DSC can be upset by the Steering Angle Sensor (SAS). That had a code for 'CAN' issues. When I checked, the angle was well off.
Using Tool32 I was able to recalibrate the SAS and then back to Scanner 1.4 and the code cleared.
With no codes and a clear dash I switched everything off, waited ten minutes then started the car.
Still no lights. Steering turned lock to lock and still all clear.
However, when first started the engine still seems to run up a little high then settle back down.
One of the vanos codes came back, but again it cleared and after three more starts has not come back.
I am not entirely convinced things are as rosy as they seem.
Janis did say the ABS lights were intermittent.
I half expect them to come back after a drive. In which case I hope it doesn't hide away until Mark is halfway to Spa.
I will be discussing with him taxing and insuring the car for a month so I can give it a good shakedown. But being on holiday for half of March it makes more sense for me to do other work on it then road test in April.
Janis did include a 'reconditioned' DSC unit in the boot. Fingers crossed it's not needed though.
The final issue was a code for the PDC. Tbh it seems to be working ok, but i cannot clear the fault.
Obviously, any input to any of the faults and codes, or suggestions for further investigation, will all be gratefully received.
