PowerTune Widnes - anyone used them ?
gremlin
Hi all - I'm looking to get my N20 engine remapped and have had these guys suggested.
Has anyone any experience with them ?
I’ve not used them / heard of them..but..
Their out of date website (2012) and Facebook (2016). doesn’t fill me with contemporary confidence….
There are other suppliers available….
Agree with the above. N20 re-mapping is so common that every man and his dog is doing it. If you look at claimed figures, they will all be very similar, as they all use the underlying same map. Unless it's a bespoke map done in real time on a dyno to your specific engine's characteristics, but marketing plays a part, so they all claim to be the highest output.
If they are claiming 280 ish bhp and 350ish NM torque, they will be the same map. Pay your money, take your choice.
Whoever you choose just make sure its on a dyno so you have some representation of any gains as opposed to writing on a box/app or promises..
A bit late to this thread but...
I had my N20 done at dc remapping in Warrington 18 months ago. Car is running great and not had any issues.
https://www.dcremappinguk.com/
Have you got a dyno chart you could post?
Thanks, looks like a pretty typical N20 engine and associated tune. :thumbsup:
What model year is your car?
B21 said:
Thanks so that's a pneumatic waste gate control turbo..makes sense.. :thumbsup:
Guys, what can you say about my dyno results?
Original HP is way lower than your results, (some says it might be about the octane levels.)
It comes back to life after remap, same 260’s.
But torque is a bit higher than all stg1 remaps I have seen. (Which is also the gear tq limit.) Do you think it should be lowered?
What model year was your car and type?
Looks like a 18i as a base line…
Often tuners tweak / end up with more mid range torque at the expense of ultimate hp..not a bad thing for road use, especially with the auto box..
cwunch said:
It is a 2014 model, m sports, 2.0i, which should be 184hp.
All of the 4 cylinder turbo cars are 2.0, either 18i, 20i or 28i varieties - it’s strange the tested power was the 18i level?
Could it be the HP and BHP difference? The manufacturer's figures are BHP, not HP.
Do most dynos maybe make an allowance for the losses so the HP figure is actually the BHP? Maybe this one doesn't?
Just a thought.
Just a thought.
Good points…usefully the chart actually shows several data lines…
The useful lines are the raw initial BHP run, a correction factor applied to it and then also rear wheel horsepower…
So in the uk where we tend to use crank BHP (US tends to use wheel horsepower) the numbers all broadly correlate with past experiences..the baseline figure should be around 185 BHP ish this puppy shows 150 BHP ish..
However the re-map jump comes into line with a broad range of other N20 re-maps.
Given the tunes are similar but not identical the profile of the re-map looks ‘normal’
The baseline torque figure shows the typical ‘brain damaged’ / ‘slugged’ profile of a de-tuned N20.
So it looks normal sort from the fact it looks like a 18i engine not a 20i..
I find it hard to believe BMW put the wrong badges on. It could happen, though, I suppose.
Normally there is a lack of enough data so you end up with conjecture…
However with such bounteous data it’s difficult to come to any other conclusions than:
1) it’s 18i
2) it’s a 20i that somebody loaded a 18i map into it
3) Somebody fitted a 18i DME to a 20i
4) Somebody fitted a 18i engine to a 20i chassis
