Power Steering Fault light On
Hi, I have a 2004 E85 2.5 which I purchased last year and have just done around 1200 miles since the purchase date, the car has had no problems during this time and even the notorious power steering has been smooth and faultless. However, the steering fault light has suddenly come on without warning and the power steering is not longer working. I have the Creators C310+ diagnostic unit but it cannot communicate with the Steering ECU unit although it communicates with all the other ECU units in the car. I know the steering ECU has a failure record but before I strip the unit out for check up and servicing, are there onboard things I can check to possibly eliminate the steering ECU. I wondered whether there is a separate fuse for steering ECU and this could have failed.
This is the biggest problem with the car. You need to get the power steering module rebuilt by ECU testing.
Take out your column. Remove the power steering module and then send them the power steering part.
They will rebuild with a lifetime warranty
firebobby said:
Don't need to remove the column, the motor/ ECU will come out.
My mechanic did it that way. It's supposed to be a pain just taking the EPS module out on its own as it's right space to work in. It's only 2 bolts holding it in place.
Not sure how many bolts hold it in, surprised of it's only two. I removed my motor.
I'm talking about the module itself holding to the column. It's only 2 bolts if I recall correctly but they are much easier to remove with the column out than in
You don't apparently NEED to, however you have to do nine tenths of the work of removing the column to get the motor so you my as well just do it as it's MUCH easier. I couldn't get the motor out on its own, just wasn't enough room so I took the column out instead.
I had the dreaded EPS failure a month or two back and as others have said, sent the motor off to ECU tuning (go via their Ebay page here - https://www.ebay.co.uk/itm/401352168863 - as it's cheaper than their website) and now it's back and all fixed.
I removed the seat for better access, steering wheel off, lower column shroud off, footwell panel off, then unbolted and removed the EPS motor.
I did not disturb anything else at all, no loosening of column bolts, nothing.
Including the 30 minute wait after disconnecting the battery, the whole removal took a shade over 1.5 hours.
Refitting was around an hour.
If you have a manual car you need to depress the clutch pedal with the back of your head to get clearance to pull it out.
Apart from that it seems another one of those mythical jobs that turns out to actually be straightforward.
Unless you're all hulking great rugby players with hands like shovels I personally feel you're over-egging the difficulty.
(I will add the caveat of 23 years experience fixing fast jets where everything is hidden away like that)
I genuinely can't understand how you could remove it without dropping the column as there's no room to slide it out? Fair enough if you did, I could not. Not everyone has years of taking cars (or jets) apart...
Yeah, that was my covering note at the end. I did manage it and maybe I was lucky? Who knows? but I did come away with the knowledge that I'd happily do it again.
Bit like the roof motor guys who can do two per hour. Still takes me ages, but I get there in the end.
PS. Gutted you didn't spot my little homage to you with the 'over-egging' bit. :poke: :D
Many thanks to you all for all the informative replies. Will look at the problem first thing tomorrow and try and choose the least complex way but a couple of questions to those who have done the job -
1) I was lucky to get the fault come up just as I was putting the car into garage (so not out and about), is the car driveable with the fault on, I appreciate if it is that the steering will be very heavy and would this heavy effect partially be due to try to also turn the electric power unit ??
2) Can I just drop or lower the steering column to give more access to the motor or must I completely remove it ??
3) How long does ECU Testing take to do a refurbishment ??
Anthony
1. Can drive it but really heavy at low speeds
2. As stated before, I didn't touch anything on the column at all and managed to wiggle it out. (Basic rule is, disturb as little as possible)
If you'd like me number for help if you get stuck, PM me.
3. I ordered via Ebay on Sunday evening. Monday morning first thing they emailed me a postage paid label. Monday midday DHL collected. Wednesday morning they phoned to say it was done. Thursday midday DHL brought it back.
enuff-zed
Thanks for the offer of help, I'me usually fairly good at difficult car DIY but this is my first big job on the Z4, but will keep your PM in mind if I get stuck. I'me hoping that the fault is in the EPS unit and not any other area of the steering electronics such as the torque sensor. It would have helped if my diagnostic unit could have connected with the EPS system.
portculisz4 said:
enuff-zed
The main things that highlight it as the EPS motor are the fact that it will not connect and also that the Sport button doesn't work.
Pretty sure from your description that it is the motor in your case.
ECU Testing will refund all except the postage if they can find no fault with the EPS motor or its ECU.
Before you take it out, use a marker pen and draw a line across from the column, through the spacer ring and onto the motor body.
Then it'll easily align when you put it back.
I struggled to get room to fit a torx socket onto the bolts, but discovered that a longish ratchet ring spanner (8mm) will do the job too.
It's at full reach, so not easy to relocate the bolts on refit.
Fit the bolt into the ring spanner, offer it up to the hole then use a screwdriver to apply pressure to the bolt head and ratchet it in.
NB. Since heard some have Allen Key bolt heads instead, which may prove more fiddly?
Oh, and before you wedge yourself in there, stick a nice thick rag on the clutch pedal as you'll need to depress it for clearance and it's easiest to use the back of your head. :lol:
I Think if this happened to mine I would be seeing it as an excuse to change to a hydraulic system as on the M and get rid of this electronic nemesis once and for all!!
Well maybe, but the cars are nigh on 20 years old and all these faults are just starting to appear.
For the sake of £300 and a couple of hours work I reckon it'll be good for another 15 years at least.
One last question on EPS motor/ECU removal. I intend to try and remove with column in place, I know its going to be fiddly but since it has obviously been done this way before I will give it a go. My questions are -
1) Is it necessary to remove steering wheel,
2) Does it help to lower column slightly to give more work room
Ant other tips ( to those already given) would be appreciated
Anthony
Anthony
I removed the seat and steering wheel. Steering wheel is optional but gives much easier access when you're clambering in and out.
Then I removed the lower column shroud and the panel in the footwell.
That was it.
I suspect lowering the column would help, but as I said, I wanted to disturb as little as possible.
Just to repeat the warning, there are three plugs. The big fat one is easy to pull out in situ. The other two aren't, so I lowered the motor out and then unplugged them. But the loom isn't quite long enough to rest the motor on the floor, so you have to lower it then wriggle out and support it while you undo the plugs. One of them has it's loom tie-wrapped to the motor too. So have a pair of snips handy.
I didn't bother to fiddle around tying it back up on refit, just made sure it was safely routed.
The plugs can be pushed back on after the motor is in place.
Anthony
This is how I did it
https://z4-forum.com/forum/viewtopic.php?f=3&t=105626&hilit=steering&start=30
enuff_zed & firelobby
Excellent information, you have both given me the comfort I need to do this job, first thing monday (hopefully no rain) I will be on to it.
