Barty said:Chris_D said:Issue a recall due to risk of fire from the PCV heater, in order to replace the same part (with same part number) just to risk the same occurrence of failure/fire at some point in the future?
The logic of that eludes me somewhat.
As I said, what a sh!tshow.
Well, recalls usually have nothing to do with safety and everything with a*s-covering. But that doesn’t sell well these days…
It's hardly what i'd call covering your a$$ when you've determined a quantifiable and evidential risk, severe enough to initiate a large-scale recall, then replace the defective part with the same defective part knowing that it can fail and cause fire again at some point in the future. It makes no sense.
I'd be interested to see exactly what part BMW are replacing the defective PCV heater part with and if it's been subject to root cause analysis then revised and re-engineered taking the original defect into account, which according to Nathan in the video I posted is oil gumming up one end, then igniting. It should also have a new part number if so, or indicate a revision somewhere in the part nomenclature.
Otherwise, if I had an N52 engine I doubt whether I'd be taking it to BMW. I'd rather replace the part myself with an aftermatrket unit.
BMW in Europe have carried out multiple under-the-radar recalls. I remember when I bought my E36 coupe years ago when it was showing around 30k miles then hearing about the Nicasil bore wear issue and checking with the car's original dealer to see if it had been subject to the recall. Sure as eggs it had received a new engine at 15k miles! I'd bought a 30 grand car with only 15k miles on the engine for 12 grand. The dealer-reseller guy that sold it to me had no idea!
Then when I popped into a dealer in Liverpool to get a replacement key a service manager rushed over to me and said 'we need to perform some important work on your car asap.' Apparently the steering column was subject to premature corrosion and failure so they did a sneaky recall. I missed the letter cos I'd been living abroad for a couple of years.
Sneaky bastids.
:x
