robertboeke
I got my 2003 Z4 a few weeks and have gradually been working through it's "quirks". The latest being that while I was checking the B Pillar airbag control unit (I have an airbag light on and DIS says that's where), I found that under the seat was soaked all the way to front of the footwell. So I've had the seat out today, carpets up etc. and used a wet vac and heaters to get everything as dry as possible.
I think the water probably came in via the bulk head as the the drainage at the bottom of the windscreen and around the blower intake was absolutely filled with leaves, mud etc. this was all cleaned out a week or so ago.
What I'd like to know is whether there is anywhere else I should check for water ingres, I really don't fancy another day drying the carpets! Thanks.
. I used a product called Gummi Pflege on my rubber seals. I was told that over time the seals shrink and lose the elasticity they had to create that water tight seal. Gummi Pflege restores this to some degree. It helped my problem enormously. But you do have to make sure all your rain channels are clear for any of these fixes to work correctly.
