Passenger door doesnt unlock with central locking
MarcBMWZ4
Passenger door often takes a few tries with the key fob to unlock. Sometimes have to re-lock the driver door and then try again. It works eventually but its pretty irritating.
Anyone had this problem or have any ideas as to how to fix?
Many thanks if u do.
Ducklakeview said:
It's not set to "selective unlock" is it? Try two presses in quick succession from locked..
Mike
What is "selective unlock"? two quick successive presses normally just unlocks driver side door. then I lock and try again (sometimes a few times) and it opens. Seems more of a fault than a setting due to how erratic it is.
MarcBMWZ4 said:
Dave1971 said:
Do a search for GM5 module and see if the symptoms match yours.
Just did a quick search and you seem to be spot on. Same symptoms...
Thanks, appreciate the input!
It's easily repaired, there is a guy advertising a repair service on ebay for £33.49.
find my recent thread on this. had mine done by eBay chap a couple of weeks ago. problem solved and very good service. easy to get GM5 unit out but perhaps a bit daunting if you're not a spanner monkey. let me know if you need any pointers
cheers
I did it too, but the relays were £12 each so for an extra £10 I let someone else do the soldering job and get a guarantee.
