I would push the wheels out as far as you safely can with hub-centric spacers without fouling on the arch liners or protruding beyond the wheel arches. You need to use longer wheel bolts in the process.Leesfarm07 said:BTW as the offset on the front 224m wheels I've fitted to my non m are pushing the wheels slightly in by a few mil is it worth adding spacers to bring them back out to where they were with the 108's or slightly more!
+1mad4slalom said:flux capacitor![]()
Have you done this on a standard set of M wheels, what would the spacer size be? Or how would I work it out?exdos said:I would push the wheels out as far as you safely can with hub-centric spacers without fouling on the arch liners or protruding beyond the wheel arches. You need to use longer wheel bolts in the process.Leesfarm07 said:BTW as the offset on the front 224m wheels I've fitted to my non m are pushing the wheels slightly in by a few mil is it worth adding spacers to bring them back out to where they were with the 108's or slightly more!
Happy to help.a340driver said:Great information exdos:
toplad said:Hi,
I haven't modified the suspension like others on here , but that's where I would start given the chance.
There's some interesting info backed up be proper measurement here, its in a few part which cover engine tuning, suspension, exhaust
http://www.europeancarweb.com/tuned/epcp_0709_project_z4m/
