I was never able to do it after the BMW security upgrade. I bought a Smarttop Module - I iked it so much I swapped it into the new Zed. In my opinion, It's how the car should have left the factory.*AL* said:You can programme it to shut on the key.
buzyg said:Yup it's normal. You can open on the key as standard but not close it.
Why not use your old account and change the details to show your new Zed. Plus list your old one :?
ronk said:Comfort access or not - im sure none of them close without the button in the car being pressed - I was told that a child had his fingers trapped when the roof Assy closed on him.
Smartbear said:ronk said:Comfort access or not - im sure none of them close without the button in the car being pressed - I was told that a child had his fingers trapped when the roof Assy closed on him.
Mine doesn't need the button in the car pressed, it closes off the remote with a smarttop module fitted![]()
Kingfisher said:I had no idea you could open the roof with the fob! How do you do that then? Not sure I need to but I suppose it looks good. My fob has to be inserted in the dashboard slot to make anything work so maybe later cars don't have this facility ... :?
Wrs said:Kingfisher said:I had no idea you could open the roof with the fob! How do you do that then? Not sure I need to but I suppose it looks good. My fob has to be inserted in the dashboard slot to make anything work so maybe later cars don't have this facility ... :?
Just hold down your unlock button on the key fob.![]()
