john-e89 said:Is that really a good idea?...it's a prime daydreaming distraction...
Ever been on project team meetings?
markeg said:pvr said:All the windows are oak after the last burglary where the glass was simply removed from the non removable windows supposedly. Now tampered glass, the door has not been replaced yet ...
The last burglary? How many have you had?![]()
pvr said:
Who installed that then? IIRC, wiring regs require that all cables buried in walls must run either vertically or horizontally from the switch/socketpvr said:Even more annoying that the channel from the light switch up goes at a 30degree angle to the left..
PerryGunn said:Who installed that then? IIRC, wiring regs require that all cables buried in walls must run either vertically or horizontally from the switch/socketpvr said:Even more annoying that the channel from the light switch up goes at a 30degree angle to the left..
john-e89 said:PerryGunn said:Who installed that then? IIRC, wiring regs require that all cables buried in walls must run either vertically or horizontally from the switch/socketpvr said:Even more annoying that the channel from the light switch up goes at a 30degree angle to the left..
They probably left themselves a bit short on the cable run and had to run at an angle to get to the switch rather than pull it all out and run a new cable in.
Not saying it's right but that's the usual trick, once it's skimmed the next anyone knows is when they drill the wall thinking they're away from the vertical run and BANG. Hence I use a cable detector before drilling as I've seen this too many times, it really pisses me off when it happens as it's a complete PITA to repair.
lux said:That looks great, is that pic your car? Can't wait for the Cayman now!
Until someone else tries to drill a hole and goes through it...pvr said:I hit the metal cover so no damage done ...
I think that the requirement for buried cables to run vertically/horizontally goes back a lot further than 1999 - I seem to remember it being a requirement back when I bought my first property in the 80spvr said:I build my office in 1999, so not as strict as it would be now.
That's not the point - and you know itpvr said:All fully RCD-ed![]()
