kerstien said:
I too have pulled the plunge and ordered kw v3s after reading all the info supplied by exdos. Thank you for providing so much information on the matter. My car is a DD and I just can't live with the bumpy ride on the bad roads we have In Malta.
Is there anything else I need to update whilst installing the new suspension?
Exdos I tried looking up your alignment settings and from what I gathered you are running 0 toe front and back, -1.3 camber front and -1.0 camber rear. Can you confirm these settings and are they adaptable for daily driving?
Dondp, since the kws have so many settings can you maybe suggest where I should start from.
Kerstien
I would recommend that you either fit Rogue rear top mounts or fabricate your own rear top mounts (as I've previously described elsewhere) that are inverted, so that you can remove/install the dampers from the underside in the wheel arch.
You've correctly listed my geometry and that's what I run on both public roads and at The Ring. With my suspension this works great.
With regard to initially setting up your KWV3s (essentially the same as my AC Schnitzer Racing suspension), if your use is primarily for a DD and road use, I would set the front up at quarter of the range from full soft and the rear at full soft and then progressively increase the settings until you feel that the suspension becomes too stiff at either end of the car, and then back-off that end by one adjustment. You will find that the rear suspension settings essentially determines your perception of the ride of the car and softish settings are best on the roads. At the front, you will find you can go stiffer than at the rear, and the front will feel too stiff when too much of the bumpiness of the road is being transmitted to the steering wheel; when you get to that stage, back off the front settings by one adjustment. Once you feel that the car is both comfortable and handles well, drive the car for a while so that you can experience the car on as many different roads surfaces as possible, and then you can decide if it's necessary to fine tune the settings. I have KWV3 on my Z3MC, but this variant has separate rebound and bump/compression adjustment: for road use I have the front at 50% from full soft and the rear at around 20% from full soft, but on track I have both the front and rear at around 90-95% from full soft. You don't want to be a "hero"with stiff suspension settings on public roads, because your car will handle badly and the ride will be dreadful.
