AnilS said:I was told by my indie it might be low battery power as it's not been driven so I have a trickle charger on and I'll see if it clears tomorrow.
Maybe a sensor, as per link above.
Andrew Sheldon said:Weirdly enough I had the same two lights come on yesterday and was going to ask the forum the possible causes but Z4mal beat me to it. Mine is intermittent in that if you turn the engine off it clears but seems to come back on again, at least it has done the one time.
Where is the ABS sensor located btw..
Z4mal said:Open the bonnet, top left corner in front of the master cylinder - you’ll see two of them. Best to replace both sensors - they’re not expensive and it’s a quick job. Just remember to seal the brake fluid reservoir with some clingfilm to minimize the loss of brake fluid when you unscrew the sensors.
I am one of the confused i was refering to brake sensors in engine bayph001 said:People are being confusing with their terminology here. ABS sensors generally refer to the wheel speed sensors, the pressure sensors are on the brake master cylinder (deleted on N52 engine).
A wheel speed sensor fault will typically bring on the tps warning light along with the other two.
Z4mal said:and the removal of the wheels to look into the sensors ( not a job for me)
Z4mal said:Need a code reader on it to be sure but likely to be the abs pressure sensors (easy, cheap fix) or brushes on ABS pump.
Z4mal said:Great thanks I’ll take a look I’ve also been recommended the Autophix 590 which is a little more so going to compare the two and place an order today. I’ll let you know how I get on.![]()
