Cheburator
Aliv6 said:S85 V10 is far from being bulletproof! Loads of issues around the clutch, transmission and sensors...potentially a big can of worms!
The Z4 is also far from bulletproof, i've had more issues than my pals old C4S! And the Porka AUC warranty is for 2 years! It's a significantly more expensive car, yet the servicing is on parallel to the M...
Food for thought.
I'd be looking at TTRS or 997T next...
I don't want to start an argument here, but:
The S85B50 is the engine, not the gearbox... The engine is bulletproof. the gearbox too. There has been two, yes, you did read correctly, reports of gearbox failure on the M5 board. That's pretty good in my book. The so called "red cog of death" is not an issue with the box, but usually with the release bearing and BMW will cover it under warranty. Sensors, schmensors - they are covered by the AUC warranty - last time a lambda sensor went pop on my E61 M5 I dropped the car in the morning and collected it the following evening. Free taxi service to and from the station. Seriously. a 997, unless it is a TT or has a GT in the model designation should not be in the same sentence as the M6...
P.S. My E61 came with a 2 year warranty - if you ask nicely, it is available...
