Newbie After bit of Z4 advice and help
Nictrix said:
Ole gits rule said:
Pbondar said:
According to RobbiZ4 the ultimate doyen of E89 roofs that statement is incorrect..
There was a change in hydraulic circuitry from 3 valve circuits to 4 valve circuits but that had zippo to do with ability to open the roof at any speed..it was part of ensuring a more positive closing procedure..there was no roof stiffening..
AFAIK if your roof doesn’t move underway then it can be coded :thumbsup:
Not a guru on the roof but the op has a 2011 23i so he either needs smart top or coding, no-one has mentioned coding but quite a few have said smart top is the way to go which is odd as I would have though coding would be cheaper :?
The Op has said he can raise and lower the roof using the fob, this would suggest to me that he possibly already has a Smarttop fitted or something similar.
He must have comfort access then.
I do not and can open only with the FOB and open on the move, with the consol button obviously.
Done it a few times, when slowley approaching red lights. (Get a few thumps up when you do it :thumbsup: )
Weird this is, when i got the car there had been an HPI check on it. When back hope going through the paperwork
i noticed the HPI check under options it listed Comfort access @ £1550.-- I dont have it.
It does not mention all the other packs i have, lighting, smoker, storage, design pure traction etc. Seems i have every option other than comfort.
If these Comfort access keys are the ones theives can read from out side your house, then i'm glad i do not have it :wink:
Scharnhorst said:
Just bought last week a 2011 model year Z4 23i Auto with 58k on the clock, Full BMW history, Alpine white with I guess a few factory extras when new, leather seats, sat nav, park sensors, autobox.
Now I am not new to BMWs as I have a 2016 330d M Sport saloon but struggling with a few features as no hand book.
1. Is it possible to get paper owners/operator manual for the car, I have tried google without much luck?
Any advice/help appreciated. Thanks :)
There’s a handbook currently being advertised for sale on EBay if that’s any help ?
I haven’t tried the roof close with the key fob yet but will give it a go tomorrow and try and get some better cleaner pics without other cars, but she needs a wash first.
Thanks for the comments and tips.
If you don’t have run flats ( I’ve had them for 5 years on my 330d) what do you use in case of a flat? Tyre weld in a can or carry a space saver spare ?
tiglon said:
1. Could try Ebay, they can also be found in digital format online.
2. If I remember correctly the pre-LCI (which yours is) need to be stationary to operate the roof.
3. No experience of your gearbox, but could it just be that it holds the gears longer therefore staying at higher revs and making more noise?
4. Again, not sure on your particular model, but on my 30i I think sport/+ just changed the throttle response a bit and turned off some assistances - wasn't hugely noticeable.
5. Apart from standard issue Bridgestone RF's I've only used my current Michelin PS4S on a Z4 and they are brilliant to drive on but definitely not the quietest so you should probably rule them out. You will soon be bombarded by "ditch the runflat" responses, which I would agree with - I think I've heard that the Goodyears are good for noise.
6. Pre-LCI they are push/pull or pull/push for up/down or down/up.
7. Apologies, I thought I was going to be more helpful than I actually was - some more knowledgeable people will no doubt comment soon!
I spotted a white 23i in Hadleigh this week, although I think I've seen it there before so probably not yours - either way, e89's look great in white and that 6 cylinder engine is glorious :thumbsup:
P.S. welcome!
If that was Hadleigh Suffolk and in the Main Street, that could been me on Wednesday evening :thumbsup:
I'm also a new member to the Z4 club - I have the owners manual, its the same as this one on eBay - https://www.ebay.co.uk/itm/154501189579?hash=item23f8fd0fcb:g:8LUAAOSwGOFgp6c2
And it can be downloaded here - while nice to have a physical copy, its doesn't have a search facility I've needed to look up the few things I needed direction on! - https://www.bmwsections.com/docs/z4/
I ditched the 4 Bridgestone Potenza runflats on my E89 a couple of weeks ago.
My research for non runflats ended up with a choice of either Goodyear or Michelin
Finally decided on the Michelin Primacy 4 - 225/45R17 94Y XL TL which have a 68db
rating for external noise, fuel efficency A and wet grip A (European labelling)
I had 4 fitted for £380 (£95 each) which I thought was a good price.
Happy with my purchase so far. Take your time and enjoy the ride.
Ole gits rule said:
Pbondar said:
Personally I think the smart top is largely a waste of time..the one thing it does that cannot be simply coded is one touch remote closing of the roof..which is technically illegal in most markets..
All other aspects and limits can be software coded AFAIK.
Technically the last thing you want to do after you’ve shut the engine down and maybe going to sleep for a prolonged period of time is induce a massive current drain with a smart top.
Not necessarily relevant on a NA engine but good practice on turbo charged cars is to let the car idle for at least 1 minute..that gives the perfect opportunity to power the roof up with the benefit of the alternator powering all systems to the last moment.
But people bang on about it like it’s a divine miracle..
Well I bought my smart top cheaply used at less than £150 so for me probably no different to buy Carly and I am not ne to mess with vehicle software to be honest so it made sense to me.
I always open / close the roof off the key and have no issues with the battery at the moment, car is rarely used did 30 miles in One but it does get put on a trickle charger for a day every week which seems to keep it working ok.
I used to do that with my RS Turbo may moons ago, not certain its needed now but I would still do it out of mechanical sympathy for the car.
Smart top could waste if you have windows that bounce when you close the top.
So, not to add confusion, but my 2010 car will open on the key fob and close with the physical key inserted in the door and held in the lock position. I realise this closing function is not new information for people.
However, playing around with my new OBD reader, I was able to recode (not that I intend to use the function due to mechanical sympathy) the wing mirrors to fold after the roof closed.
I also got the roof to open and close on the move (a choice of 4 speeds were offered). I am going to set it to 10kph and only ever use it if it’s desperate (starts raining at the lights with angry people behind).
Scharnhorst,
Nice looking car!
You might already know this, but I recently serviced my roof (nothing major, just applied fresh lithium grease, changed the Salmon relays and used some GummiPfleger on the seals). It now opens and closes about 3 seconds faster and a lot smoother (I dread to think the additional strain the mechanism was under previously).
I also agree, the engine note gets sweeter in Sports mode, but we don’t have a flap, so it can only be the higher revs as previously mentioned.
Ex 23i owner...
You can download the drivers manual as an app 'BMW drivers guide'
When you select sport a servo motor on top of the engine (a bump half way down the plastic engine cover) changes the cam lifter positions and increases vave opening and duration.
You can find a really good vide on youtube about stripping and the function of the N52 cylinder head.Michelin pilot sport 4 (4s) is always the best choice as anyone who has tried other so called performance tyres will tell you.
Opening the roof while moving can be coded via the carly app, so long as you are under 30mph and not cornering etc itll be fine.
mcbutler said:
Ex 23i owner...
I’ve not heard that before, the engine makes no more power in sport mode & the perception of greater response comes from the fly by wire throttle mapping being altered to give more throttle from the same pedal position :?
Smartbear said:
mcbutler said:
Ex 23i owner...
Sorry my mistake, when full throttle is applied the valve motor increases valve lift from about 1mm to 10mm.
Video link, starts at around 4 min in https://youtu.be/3gRhDKE8vKU
