Nictrix said:The Op has said he can raise and lower the roof using the fob, this would suggest to me that he possibly already has a Smarttop fitted or something similar.Ole gits rule said:Pbondar said:According to RobbiZ4 the ultimate doyen of E89 roofs that statement is incorrect..
There was a change in hydraulic circuitry from 3 valve circuits to 4 valve circuits but that had zippo to do with ability to open the roof at any speed..it was part of ensuring a more positive closing procedure..there was no roof stiffening..
AFAIK if your roof doesn’t move underway then it can be coded![]()
Not a guru on the roof but the op has a 2011 23i so he either needs smart top or coding, no-one has mentioned coding but quite a few have said smart top is the way to go which is odd as I would have though coding would be cheaper :?
He must have comfort access then.
I do not and can open only with the FOB and open on the move, with the consol button obviously.
Done it a few times, when slowley approaching red lights. (Get a few thumps up when you do it
Weird this is, when i got the car there had been an HPI check on it. When back hope going through the paperwork
i noticed the HPI check under options it listed Comfort access @ £1550.-- I dont have it.
It does not mention all the other packs i have, lighting, smoker, storage, design pure traction etc. Seems i have every option other than comfort.
