New MOT Test Results Check Site
cj10jeeper
 Lichfield, England
New site at the DVLA that you can check MOT's with just make and registration.
https://mot-history.net/
Shows all the passes fails, advisories, etc. and mileage so looks like a great pre purchase site to view.
Found my Jag actually failed on a sidelight bulb, was fitted and retested, passed and the centre never even told me...
Ah yes, excellent indeed.
Failure for my Golf last year ...
Reason(s) for failure
Front Windscreen washer provides insufficient washer liquid (8.2.3)
Looks even weirder that this list was in 2010 and never made an appearance again ....
Nearside Front Upper Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Offside Front Upper Macpherson strut has slight movement at the upper attachment (2.5.A.1c)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Nearside Rear wheel bearing has slight play (2.6.2)
Offside Rear wheel bearing has slight play (2.6.2)
Front Brake pipe slightly corroded (3.6.B.2c)
Exhaust has a minor leak of exhaust gases (7.1.2)
Both rear brake flexi hoses are a little soft. But not bulging or moving under pressure
one fail in its first year!
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Rear Tyre has ply or cords exposed (4.1.D.1b)
Advisory notice item(s)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
that aint bad :) that would have been a dear MOT :D
just done one on my daily golf its been clocked!!!
Test date1 March 2014
Test ResultFail
Odometer reading170,146 miles
MOT test number5491 1086 4062
Test date2 February 2015 Test ResultFail
Odometer reading139,821 miles
MOT test number3182 5353 5087
:O why would you be arsed clocking it 30k lol
There you go guys - a host of interesting stuff.
Clocked car :(
Same as you pvr - All my Z4 advisories of one year except for brake pipes and service items like tyres were not fixed as they looked good to me and vanished the following years
Amazing that there is something useful on their site for a change, but yes - excellent tool for a buyer to verify what advisories there are that have been hidden from the sales advert ...
My old X5 does not show up, I guess the new owner put a private plate on it then.
My Z doesn't show up!
Found my first car (2001 fiesta) has been clocked - why? And my second car a 2003 Mini had no advisories before it stopped getting tested in 2012 so can assume that met a swift end!
Great site
:thumbsdown: Ha ha - my neighbours car has failed 6 times since and inc. 2009....
Given the number of faults I'm wary of him even being able to get out of our street without something breaking
Right - must get on with some real work
MOT history of this vehicle
Test date: 29 November 2014
Expiry date: 7 December 2015
Test Result: Pass
Odometer: reading 123,234 miles
MOT test number: 5099 7303 4318
Test date: 30 November 2013
Expiry date: 7 December 2014
Test Result: Pass
Odometer reading: 98,299 miles
MOT test number: 9492 2403 3314
Test Result: Fail
MOT test number: 1372 4493 3338
Reason(s) for failure: Nearside Headlamp not working on dipped beam (1.7.5a) (turned ignition off/on and it was working again)
Test date: 3 December 2012
Expiry date: 7 December 2013
Test Result: Pass
Odometer reading: 73,088 miles
MOT test number: 5492 3883 2376
Test date: 26 November 2011
Expiry date: 7 December 2012
Test Result: Pass
Odometer reading: 53,307 miles
MOT test number: 5698 3013 1363
Advisory notice item(s): Oil leak (fixed under warranty)
Test date: 2 December 2010
Expiry date: 7 December 2011
Test Result: Pass
MOT test number: 7503 4683 0312
Test date: 18 November 2009
Expiry date: 7 December 2010
Test Result: Pass
MOT test number: 7419 9202 9355
This is my only advisory:
small stone chips front windscreen.
Under-trays fitted obscuring some underside components
What a joke. Never picked up before or after and its the same windscreen and the OEM under tray is still there.
Under tray is always mentioned as they are not allowed to remove it to check underneath. Guess to cover themselves.
But I have only ever had it mentioned once, which is what I find strange. Its been on there since new, and still is, but only once has it been an advisory.
Yes - agreed about that, but they generally mention that - they always did on my M as well.
More worrying is that reported 'issues' are never reported again. It is the same exhaust on my Golf for the last 22 years so how can it leak 4 years ago and never since, or any of the other stuff. It has been MOT-ed at the same garage as well, so not even the case that it was at different places.
different testers pick up on different things. different days affect different testers, they're only human.
I had it mentioned on my 330, not on my z4 from the same tester, both cars have undertrays fitted.
my old z4 doesn't seem to be very loved anymore :(
advisory in every one of the MOT since my ownership...
Nearside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
and
offside front aluminium subframe damaged / front subframe damaged :o
since May 2014...
seems there was a gap too - NO MOT from Dec 2013 - May 2014
nice site though :D
