Need recommendations for hand held obd2 scanner
Need to double check but think it was green/white wire in the boot through a switch I've placed where in my cat the boot open switch resides in that option cars.
green/grey wire
Wouldn't be without my Foxwell in the car.
I look for boot open option, but can't find any.
Still i fitted a separate switch for that. Had to use that a few times.
Did you try the following these instructions..
Steps to Open Z4 Boot with Foxwell NT530:
  1. Connect the Scanner: Plug the Foxwell NT530 into the OBDII port and select the BMW-specific software.
  2. Identify Vehicle: Allow the tool to perform a smart scan or manually select your Z4 model to establish communication.
  3. Access Modules: Navigate to the Body or Body Control section.
  4. Select Junction Box/JBE: Locate the Junction Box Electronics (JBE) module.
  5. Activation/Active Test: Choose Actuations or Activation to send commands to the car.
  6. Trunk Release: Select the "Trunk Release" or "Tailgate Lock" option to trigger the release mechanism.
green/grey wire
A wire from the boot? What wire? And then a grey and green wire in the cabin? and now it’s lying free? Where is the switch or what switch? Would need more and clear details
This could be very useful, going to print this out and keep it with my scanner in glove box, although foxwell says none of their scanners open the boot?
