Greeno said:Cheers AJ
Well after another half hour i finally mastered the technique!
Yippee i thought...................
tested OK, put everything back together..........
And there is a dodgy connection or a break in the cable somewhere.
But i did find that once you know where the socket is if you pop the angled panel below below then there is no need to remove the vents.
So now when the replacement turns up at the stealers it'll be a 2min job. famous last words!
