bladeowner said:If you press the right hand knob when sat nav is in working mode, a window pops up and you can untick the instruction box to mute the voice. Unless newer ones are different.
RobJJZ4 said:bladeowner said:If you press the right hand knob when sat nav is in working mode, a window pops up and you can untick the instruction box to mute the voice. Unless newer ones are different.
Thanks, I will try on the why home and see![]()
RobJJZ4 said:RobJJZ4 said:bladeowner said:If you press the right hand knob when sat nav is in working mode, a window pops up and you can untick the instruction box to mute the voice. Unless newer ones are different.
Nope that didn't work....![]()
RobJJZ4 said:Press Knob, select Information or Instruction (Depending on version), press and HOLD knob, and it turns it off![]()
bladeowner said:RobJJZ4 said:Press Knob, select Information or Instruction (Depending on version), press and HOLD knob, and it turns it off![]()
That's what I said........ or meant![]()
Z4 Coupe said:This doesn't work for me?
When I press instruction it just repeats the last instruction. What am I doing wrong?
Z4 Coupe said:Yes it was me being thick.
It switches back on again when I get back in the car but that is much better than nothing. Whoever designed this radio must have been mad!
Anyone know how to switch off GALA? (The thing that changes the volume depending on how fast you're driving)
:roll:RobJJZ4 said:My volume is off to hear the engine or on full??? Must be the way I drive:roll:
