Hi all,
Went to nip out this afternoon in my 2006 2.5. Started her up and could hear a sort of humming noise which was kind of going 'up and down/rising and falling' if that makes sense? Wondered if it would just vanish on its own so drove off and it appeared to disappear after a mile or so. Got out of town and after a couple of miles noticed the temp gauge had shot up, as I slowed to pull over into a layby the red warning light came on and the warning noise pinged. Switched car off and popped the bonnet. Couldn't see anything obvious so after waiting for 15 mins or so I set off again but about turned to head for home instead of continuing my journey.
The 'rising/falling' noise appeared to have gone but the temp gauge needle was pretty wildly fluctuating up and down quite randomly. As a precaution I fired up the heater controls to max temp and full blast and continued slowly and carefully home. Needle went up and down a bit but it mostly behaved - although I was roasting in the car with the heaters on full!!
When I got home, I plugged my Carly OBD in and its showing an error 002E81 - Electric Coolant Pump, speed deviation
I presume that means my water pump is beginning to fail? Car has just over 159k miles on it and had been performing brilliantly up until today, previous owner had not changed the water pump during his ownership so I've no idea if its the original one or not.
Any advice appreciated, ta.
Amber light followed by a red one in less than a mile. As I was 12 miles from home I used the RAC.
