N46 MAF Reads 0
OK the pins and colors I gave you are correct. As far as the ground, you can use a chassis ground. The other three pins with the connector disconnected (key off) "should" show a ground (I think). The DME for these three wires uses internal transistors and in a steady state (key off, disconnected) should show a ground. I'm not an electronics expert so a little fuzzy on transistors
Alrighty,
Tested this today, pin #2 and #4 I have 12.5V and 5V
Pin #3 & #5 I have 0V
Pin #1 I have 5V to chassis ground.
Anyone able to tell me if pin #1 should be 5v?
Looking at the wiring diagram if the connector is disconnected I would say no. If it is connected I don't know because there is no diagram of the inner workings of the DME logic board.
