Mr Tidy said:Smartbear said:There, I’ve fixed that for you - no need to thank me
Get back to me when you have a 4-pot that reliably gives more performance than an S54.:lol:
Iain.
You’re forgetting where you came from already
Iain.
Smartbear said:You’re forgetting where you came from already
Mr Tidy said:Smartbear said:You’re forgetting where you came from already
No more than you!:lol:
Smartbear said:Mr Tidy said:Smartbear said:You’re forgetting where you came from already
My reply was in response to the 3litre owners Lain, the n20 can outperform them![]()
Wouldn’t sound as good though would itSilverstar said:Smartbear said:Mr Tidy said:No more than you!:lol:
It would be interesting to see just how much of a difference in performance the N20 has compared to the 30i N52. The stock 28i and 30i figures in terms of performance are very very closely matched and there is hardly any difference between the two. Even the curb weight is just 15kg difference between the two. So yes a tuned 20i or 28i to around 280 bhp should be quicker than the 30i but it would be interesting to see exactly by how much. Maybe someone needs to put them side by side and time them / drag race them.
Smartbear said:Silverstar said:Smartbear said:My reply was in response to the 3litre owners Lain, the n20 can outperform them![]()
R60BBA said:Wouldn’t sound as good though would it
Smartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
How would an aftermarket exhaust setup sound with the N20? If it's good, one less reason to 'diss' the 4 potSmartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
Silverstar said:Smartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
Just out of interest what sort of real world fuel consumption do you get from your 20i?
enzed4 said:How would an aftermarket exhaust setup sound with the N20? If it's good, one less reason to 'diss' the 4 potSmartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
Rob![]()
For performance cars the standard measure of performance is the 1/4 mile time, 60-130mph times are also a good metric. 0-60mph is a measure of traction so making theoretical assumptions based on power increase alone is a fools game.Smartbear said:Silverstar said:Smartbear said:My reply was in response to the 3litre owners Lain, the n20 can outperform them![]()
R.E92 said:For performance cars the standard measure of performance is the 1/4 mile time, 60-130mph times are also a good metric. 0-60mph is a measure of traction so making theoretical assumptions based on power increase alone is a fools game.Smartbear said:Silverstar said:It would be interesting to see just how much of a difference in performance the N20 has compared to the 30i N52. The stock 28i and 30i figures in terms of performance are very very closely matched and there is hardly any difference between the two. Even the curb weight is just 15kg difference between the two. So yes a tuned 20i or 28i to around 280 bhp should be quicker than the 30i but it would be interesting to see exactly by how much. Maybe someone needs to put them side by side and time them / drag race them.
A turbocharged 4 pot will never sound as good as a naturally aspirated 6 pot. No matter what exhaust system is used.enzed4 said:How would an aftermarket exhaust setup sound with the N20? If it's good, one less reason to 'diss' the 4 potSmartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
Rob![]()
Smartbear said:Silverstar said:Smartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
It depends entirely on the journey and wether I’ve got my other half in the car or notI’ve had up to 50mpg and as low as mid twenties, I've almost reached 500miles from a full tank driving carefully. I’ve had a couple of n52 zeds and the best i got was from my 3.0si e85 with 420miles.
My 30i e89 only lasted a month before it expired so never got to know it as well as the si I had previously, official figures were around the same from memory, it had a handful of bhp less than my e85 but i didn’t really notice it. I liked them both.
R60BBA said:A turbocharged 4 pot will never sound as good as a naturally aspirated 6 pot. No matter what exhaust system is used.enzed4 said:How would an aftermarket exhaust setup sound with the N20? If it's good, one less reason to 'diss' the 4 potSmartbear said:I think the n20 is a good compromise, faster than the 30i yet better on fuel and cheaper to tax, the noise isn’t as good but a turbocharged 4 sounds good in its own right![]()
Rob![]()
Pbondar said:It would be nice to have the data for a sizeable bunch other metrics such as the 1/4 mile dash etc , unfortunately BMW never published these numbers at least across all the models..
The 0-60 and 0-62 figures were published and I assume they were at worst a reasonable representation of what a competent person could do in a fresh car..at best they were using a very professional, highly experienced test driver in a carefully selected car.
They could of course had merely computed them based on relatively simple Newtonian mechanics..
The interpolation for the re mapped N20 engines takes a smoothed line through the BMW published data..
One assumes the same techniques were used for all E89s but maybe they weren’t..
On the type of tyres used, likely surface and available power subject to appropriate launch technique then for the range of horsepower tested tyre grip wouldn’t be a limiting factor..
For the simple comparison of the 30i vs a remapped N20, more bhp and more torque over a broad range would ensure the N20 some numeric supremacy..
On such a short dash whether you need to change gear once or twice has a marked effect on the times especially either with a manual or the slower shifting 6 speed ZF box..
Now if anybody can find me a standardised set of figures fir all the normal E89s I’d be happy to do some additional calculations..![]()
