My Second Zed Thread (2010 E89 sDrive30i)
Thanks - I watched all the way through Dave's 1st video last night, glad I did as there are a few gotcha's in there which would have caught me out (dipswitches, exactly which leads to use etc).
I also didn't realise it could all be done with the steering wheel in place so that makes the process a bit easier, without having to faff around with battery disconnections etc.
You only need to go near the steering wheel if you want to integrate into the factory mic which located behind the steering wheel shroud. As per the photo I posted in my audio thread I just mounted the mic supplied in the kit discreetly near the start stop button and left the original mic alone.
john-e89 said:
What’s all that nonsense Timbo....? :?
That bundle of Chinese tat lets you add Apple Carplay or Android Auto to the standard iDrive, making it a good chunk more modern.
I made the mistake of watching Dave's (Annubiszed) YouTube video on fitting it a couple of weeks ago and that was enough to persuade me to buy one - I'm very easily led :driving:
Bit chilly for fitting at the moment though.
:rofl:
Sorry, only just spotted this one, Parts 2 & 3 are now live as well :thumbsup:
Just wanted to say thanks for this write up - having just bought an E89 it's been a really useful read for me and I'd love to follow your lead as a way of keeping a record of what I do to the car.
Can I ask you where you sourced the carplay unit from - mine has the Idrive and loudspeaker options so the carplay looks like a great option?
Ta Dave, yes watched it through last night - interesting to hear about the intermittent connection issues (my phone is Android), I wasn't going to bother but I may consider running a USB back to the arm rest with the aux cable.
Great series, really appreciate the effort.
You're very welcome, glad it's of some use - there are a few ideas buries in there somewhere if you're missing some bits and pieces, as well as a few good examples of what not to do :thumbsup:
The one I bought was from AliExpress, here: (note I still haven't fitted it yet, but it's the same model other people have fitted with success)
https://www.aliexpress.com/snapshot/0.html?orderId=8123263260996283&productId=4001063666209&edm_click_module=order_detail&tracelog=rowan&rowan_id1=buyerPayOnlineSuccessToBuyerV2_1_en_US_2020-12-19&rowan_msg_id=6283812326326098$0a3b2355d1234cafa83b090ed9bf3521&ck=in_edm_other
MMI installation now finished.
Generally not too bad a job, worth having a think about where you're going to run the aux, antenna and microphone leads in advance rather than just ploughing into the job like I did - see link below for pointers (and apologies for cross posting content from there)
https://z4-forum.com/forum/viewtopic.php?f=23&t=126877
Links to YouTube videos from Dave/AnubisZed which are helpful for all sorts of reasons (dipswitches, which leads to use where, which leads to ditch, installation location, glovebox removal, MMI box set up, re-use OEM microphone etc)
https://www.youtube.com/watch?v=jY-pSPUz0IU&t=1348s
https://www.youtube.com/watch?v=KFjiNxZ3Q7o&t=536s
https://www.youtube.com/watch?v=0WDtEWtAgzY&t=950s
On the way, trim removed and head unit disconnected.
Quick test to make sure the box works ok.
Box installed to glovebox area, all leads run accordingly. At this point I had the aux, antenna and mic leads poking in the front of the cabin - the mic lead was incorrect, neads to route from the MMI box, back behind the head unit and over to the steering column.
All finished, car re-assembled.
1st service completed, all without drama.
Not difficult at all, some basic tips below if anyone is considering DIY bearing in mind I'm a mechanical simpleton.
Get the car warm so the oil flows freely, get the front of the car up (jack, ramps) and supported on axle stands.
Under the car is a helpful access panel:
The sump plug is easy to find just inside this access panel - 17mm socket, have your oil catching thingy ready to go. Remove the filler cover at the top of the engine to let things drain easier (picture below shows re-fitted bolt, untightened)
Leave this draining while you do everything else required for the service.
Undo the oil filter housing - this is a different design to my E85 which needed a large socket, whereas I assume there is a dedicated much larger tool to unscrew the housing cover on the E89 - I used a oil filter wrench in the end with a rag over the cover to not damage it.
Remove the existing filter, replace with new and the 2 o-rings you will get with the filter (one large for the housing lid, one small for the end of the central metal stalky bit. Picture below shows both replaced). Lube both with a finger of fresh oil.
Clean up the filter area - I sucked up what remaining oil I could see in the housing.
Replace the filter by screwing in the housing cover - you will get to the 'end' of the screw thread (same as the coolant reservoir cover).
Replace the air filter. 4 metal clips to undo to release the housing, I removed the forward section of the air filter housing from the front of the air intake completely to remove/replace the filter element - it was then a pain to replace the section I removed, so I popped off the 2 bolts which hold the REAR of the filter housing to the car which gives another couple of inches of movement.
Replace the pollen/cabin filter. This is in the passenger footwell, underneath the glove box - remove the 3 screws nearest the cabin, the plastic trim them removes completely. The pollen filter is under there, held on by a simple plastic cover. Mine clearly not changed for a long time. Kick yourself for not doing it during the MMI installation, even though I had the new filter sitting in the garage.
Picture below shows the cover and the leaves that dropped out when the old filter was removed. I then removed probably double that quantity again just by reaching my hand up inside.
Oil was dripping from the sump maybe 1 drip every 20 seconds at this point, so cleaned up the area (making sure the old washer was off the car - can sometimes stick to the sump) and replace the sump bolt, generally best to use a new bolt and washer - there is a published torque value but I never use a torque wrench for sump bolts these days. Tight enough then a quarter turn hasn't seen me wrong so far.
Published capacity for the 30i is 6.5 litres. I put 6 full litres is, with a view to hoping this would be adequate and the car would alert me if not (no dipstick on these remember - doh).
Double check no oil coming from underneath, replace access panel cover, replace oil filler cap, remove jack stands, lower car and start. Car can sometimes take a couple of minutes to get an oil reading - in my case it gave me the 'full' thumbs up. I then did a 20 minute journey just to make sure everything is working as expected, re-checked the oil at the end, still showing 100%. Suppress irrational thoughts that my oil level sensor is faulty (as I've never, ever had anything OTHER than a 100% reading).
Reward with cup of tea, safe in the knowledge everything has been done correctly and at a fraction of the price of taking to a garage.
Had the car 20 months now, so time to give it a nice warm cuddle.
Transmission service (new sump pan, gaskets, fluid etc)
Coolant change
Brake fluid change
Differential fluid change
New spark plugs
Replaced oil filter housing gasket
Replace valve cover gasket
All completed by a BMW indy I see recommended often but have never used, 'Mill Lane Automotive' in Warmley, Bristol - very good to deal with, gave me a Mini Cooper S as a free car for the day which was highly amusing, then billed me near enough £100 less than their quote. Will definitely be returning when I feel BMW trained expertise is required.
I'd be lying if I thought the car was even 1% different on the drive home :D but I'm looking forward to it not smelling vaguely of oil after a hard run now the leaks have been resolved. I also get a good warm glow getting non essential, non routine service type stuff done.
Excellent thread on this stuff. Have been pondering a few of these mods myself so you might have inspired me to go ahead. Also the carplay module is looking more and more appealing…
Arm rest/cup holders
My commute to work, thankfully only every couple of weeks, is 150 miles each way - 2.5 to 3 hours. Having a coffee mid way through that breaks the journey up nicely but I don't want to be stopping at services. My car came with the arm rest cup holders, which do work fine but mean you have to travel with the arm rest raised to use them - bit daft. Together with the very-out-of-date phone cradle means this storage space is a bit wasted, so I've fitted the full tray option instead.
Before starting - excuse the spilt coffee :)
Remove the rubber mats in both cup holder sections to reveal 2 of the 4 screws. The other 2 are underneath the phone cradle - I did crack this unfortunately, as do most people it seems when removing it, despite trying to be as gentle as possible.
Removing the tray leaves you with this: (that PCB is the last thing that needs to be removed so the leads can be tucked away neatly)
And finally the new tray fitted with mat in place - much better!
And so onto the cup holder conundrum. How hard can it be? Fairly :)
Here's the first attempt - only around £6 to £8 depending on where you buy from:
It has 2 quite sharp bits of plastic on the rear which dig into the leather on the arm rest:
Which are easily removed/smoothed with a dremel:
But, the outer edige of the unit is still too thin and sharp and would damage the leather, especially when the car is in motion. I bought some cheap rubber edging:
This is a lot better and should not leave any marks. Pic installed
Looks a bit naff, but easily removed and tucked behind the passenger seat as I'd only use it on long journeys.
You can also buy this same item with a very cheap looking fake leather cover which I think is applied to the front and rear, which would probably offer the same protection as my rubber strip.
Thanks so much for this. I’ve finally been able to remove the phone cradle thanks to these photos. Replacing it woth the rubber matt
Good work :thumbsup:
Yes never regretted this mod, I'm still using the same dodgy cheap cup holder and it's perfectly fine.
Yeah the cup holders are fine by me so kept them. That apple carplay module still lingers in the back of my mind though…
Unexpected surprise yesterday. Took the car out, for the first time in a while in proper driving rain - to find a very obvious leak coming in from the passenger side pillar.
Quick diagnosis when home (still in driving rain :D) to find the issue is completely self inflicted. I had the seal pulled away from the car when fitting the MMI unit, and when refitting had 2 of the adjacent rubber sections near the top overlapping the wrong way around. Doh.
30 second fix, and just happened to need another hour journey in similarley driving rain in the evening - no leak this time :thumbsup:
