I started the car and it was barely running. It would fire up and stall straight away. s**t. At this point the light was fading so I called it a day and went inside for a beer.
The next day it was time to start checking all of my connections. The small DISA plug didn’t seem to sit all the way in so a quick fiddle with that and still nothing.
I the started to look at the CCV pipes because that’s what had been changed. The new oil return pipe didn’t seem to click into place like the old one, so that was cleaned up and reinstalled. But nope, still wouldn’t run.
I did discover that it’d run with the MAF unplugged so I started to wonder if that’d had been damaged somehow. A new MAF was tried but nope.
After lots of head scratching and checking things, I found this
There is a vacuum line behind the throttle body which had been an absolute sod to get off and it was even harder to get bs I in place. This was the cause of my vacuum leak.
Out came the manifold again and I removed that vacuum line form they car make it easier to get properly connected to the manifold again.
Here’s a picture of the old CCV too. Gunky.
I also discovered the hard way that the sounder generator box needs to be con for the car to run properly. The car was now starting and idling just fine but I had a check engine light on. FFS.
The car drove just fine so I was scratching my head (still). It was at this point that my Carly app decoded to s**t itself and it refuses to complete a code read. It reaches 90% and just stops. To try and understand is going on, I bought a Creator code reader which arrived promptly courtesy of Amazon Prime. I’m left with these four codes.
Initially thinking that the car running rich with no MAF I wondered if a load of fuel had been dumped into the exhaust, killing the O2 sensors. Fearing the worst, I start looking at the cost of new ones and getting a bit of a shock I ran off to Google. The chances of all four sensors dying at the same time looked really slim and a few threads mentioned that it could be a fuse. This lead to much more time on the internet and I eventually found a list of fuses in the engine bay. Fuse four is for the CCV heating and Ow sensors….
One blown fuse. I’ll be heading to ECP soon to collect a box of fuses which will hopefully resolve the issue once and for all.
