Recently the car has received a lot of attention with several preventive maintenance items ticked off. I planned to do the cam cover gasket over Christmas but managed to accidently order the N52 gasket, which does not fit the N52K. So started off the first weekend into the new year doing a cam cover replacement, and while there, I also replaced the
eccentric shaft sensor and its gasket for good measure.
It was great to see how clean my engine is and how there isn't any noticeable wear anywhere in the cams.
For months I had been very aware of how much play my shifter had, so I wanted to rebuild it. Always put it off as the exhaust needs to be dropped and I knew the studs would not be something I could tackle in my garage with no electricity. So 1.5hrs of labour from StyleDynamics later, the studs had been removed and a set of fixings put in their place.
I ordered all the parts from Cotswolds Chelterham BMW for about £85 in total shipped.
Here's the before:
[youtube]hKaUsc7YNAw[/youtube]
Here's the after:
[youtube]sgzobitqXQc[/youtube]
I expected the play to be reduced to 2-3mm and to be an overall improvement, but definitely was surprised to find that there is no play in the shifter now and the feel is tremendously improved across all gears. I also bled my clutch slave cylinder prior to the rebuild and that made no difference - apart from the good feeling of knowing there's no dirty fluid in the clutch lines of course!
And today I flushed the coolant and replaced the expansion tank with a new one I had bought in 2019 for my E85. I've heard so many bad things about aftermarket ones since then, that I was reluctant to put the aftermarket one I had available, but I had nothing to lose but a couple of hours max, so decided to try it anyway. I'll try and dig up the link for the one I bought in 2019 because I had zero fitment issues or concerns about its quality (both seem to be a commonly brought up in the forum). I also found the job very straight forward, just don't be afraid to cleverly leverage the bottom hoses off (the only ones that wouldn't come off with a bit of pulling). I would suggest removing all the connections but the bottoms ones, then place a screwdriver between the bottom fittings propping it against the tank itself and it comes right up!
Oh yeah, two new rear tyres and all wheels re-balanced. Made me realise that one or more of my wheels was slightly unbalanced as a slight vibration over 60 mph is totally gone. Happy days.
